| CNC Wood Router Project Log Post your CNC machine building log here only. |
It all started in January when I first started looking into buying a mini mill (Sherline, Taig type) to play around with machining. Well, one thing led to another and I came across this site and the ideas have been flowing ever since. After initially buying the Solsylva plans, I was looking through these threads and realized I could design my own machine. I started cruising Ebay for parts and started designing my machine based on the parts that came available. I would search for the axis' first. I started with the X axis and found some 1 inch Thompson supported rails (48") with double pillow blocks for a smokin' deal. Then, the search was on for the Y axis. I found a slide assembly with 16mm supported rails and carriage. The Z axis went through two design changes, I wanted to be sure of simplicity and rigidity. The first version had too many variables that would compromise rail parallelism and squareness so I opted for another all-in-one slide assembly. I think I now have a very rigid design and just need to incorporate the leadscrews & steppers. My main line of work is 3d computer graphics & animation. To help with the design process, I was able to download CAD files for almost all of the parts I used for my design - then assembling the machine in 3d to work out any issues and explore ideas as I went along. I would see parts on Ebay that looked promising - download the CAD files & incorporate them into the design. The only problem is that if I liked the design, I really had to win the auction to get the parts I wanted. Critiques appreciated - let me know if you see any potential issues. Enough rambling, here's some pics - 3d rendering first. |
| i just wanted to comment and say a few things, first off... i think its looking really nice so far. So far as i can tell, my only question as far as sturdiness would be you choice of having only one pair of bearing on each axis. Although, it should be noted that I've never seen pillow block bearing like that in person. This is my first post here at CNCZone... i've been lurking around for a couple weeks now, soaking up as much info as i can...I too have been thinking long and hard about designing my own table setup, and surprisingly, the image i had in my head is pretty much been fabricated by you. at any rate, i think it looks pretty smokin. you've got my attention. Jon |
| Thanks for the comments. I found that pillow blocks are very rigid and the pillow blocks I have are double-length blocks so there are 2 sets of linear bearings in each block. The X axis blocks are 6 inches long and very tight on the rail - the weak point here is how rigid the frame is. The Y & Z carriages each have 4 linear bearings in each, a scaled down version of the X axis blocks - and since the carriages are one solid unit with not a lot of space beween the rails, they are very rigid with no noticeable play. All my axis' utilize double pillowblocks with supported rails. Again, It was just luck that I got the parts I wanted on Ebay. |
| I use 3dstudio MAX with Vray rendering plugin. I was able to download all the 8020 extrusion, bearings & slide assemblies in either DXF or IGES formats. THK & IKO guide rails and carriages were also available for download when I was working out the Z axis design. |
If you look at the pic of the closeup of the pillow block, the black piece of 1/2" aluminum sitting on top of the pillowblock is bolted to the 3060 extrusion from underneath and then there are 4 bolts going up through the underside of the pillowblock overhang to fasten the pillowblock to the 1/2 aluminum. I've attached a simple rendering of the area. |
I think it's ok for now, it would take an extreme amount of force to twist that gantry. It's fastened to the plate with 4 5/16" screws and weighs close to 40 lbs. without the router. I would probobly break a bit before there was any significant movement in the gantry, either twisting or rocking. Being that the endcaps are only 1/4", I don't think it would add much rigidity - but then again, it can never be too rigid. |
#10
| Woooooooooahhh!! Sweet! I like this! Just the basic design I've been looking for. Would these round rails and blocks be strong and tight enough to use on a 4x8 router, with a 3.5 hp or more router? I have over half a ton of 80/20 aluminum including a 3060x60'' piece i plan to use for the gantry. I also have two of the square thompson rails which are exactly 60'' long as well. Would building the gantry be a good place to start? How are our going to mount your screws? Are those rails stainless? Can those blocks be tightened later to take up any "slop"? Also, will you be using a screw/bearing for each side of your X axis? Thanks Looks great. |
#11
| The rails are not stainless, just hardened precision rails(McMaster part#59585K55) and the blocks have adjustment set screws to squeeze the bearings to the rails. I am going to try using 1 leadscrew on one side of the X first. Even though the gantry is quite heavy, it takes very little effort to move. I don't feel racking will be a problem with this gantry - if so, I can always add another screw & motor. As for utilizing this design for a 4' x 8' router, The X rails would be no problem at 8feet - You might want 2 double pillowblocks on each side though. My gantry is 3" wide - I'm sure another foot would be fine - remember, There's half inch thick aluminum mounted to the front of the 3060 and supported rails mounted to that, which really adds to the rigidity of the gantry. I don't expect any measurable deflection. |
#12
Can't wait to see the progress. That's going to be one sweet machine! Thanks! Wayne |
| My First CNC, own design, buidling in progress | arie kabaalstra | Vertical Mill, Lathe Project Log | 322 | 04-22-2012 01:40 PM |
| My Router Progress | GRS | CNC Wood Router Project Log | 24 | 09-26-2006 07:08 AM |
| Alibre design in progress | xyzcnc | Alibre Design | 10 | 06-07-2005 12:49 AM |
| second router in progress | limbo | DIY-CNC Router Table Machines | 34 | 12-24-2003 04:25 PM |
| Router Progress | samualt | DIY-CNC Router Table Machines | 8 | 12-06-2003 12:17 AM |
