Page 1 of 10 1234 ... LastLast
Results 1 to 12 of 115
Thread: On to machine #3
    Jan 2005
    On to machine #3
    Well time to build a new machine, construction will be 2x3 1/8 wall rect steel tube.
    drives will be ball screws, on abba linear rails powered by servos overall working envelope will be around 68"x32"
    Jan 2005
    Well got around to drawing up the gantry, probably going to do the z assembly in aluminum....
    What do you guys think so far?
    Feb 2005
    Netherlands
    Looks good. However,
    It's quite different from the way that I would construct it.
    I would make an U-formed table, with on top, the linear slides, so that the gantry wouldn't have to be that high. This dramatically increases ridgity!
    More like this (set-up of the high beams with low gantry).
    Jan 2005
    But then i would have to try and sync two servo's for the x drive as the distance is too far for a belt drive...
    Jan 2005
    Well new design
    Z will still be direct drive ball screw
    x & y will be a 3 to 1 reduction using 495oz steppers
    Rack and pinion 24t 14.5 deg
    somewhere around 5x9 travel
    so dual steppers on the x and single on the y
    the y beam is 2x6 1/4" steel
    the x beams are 2x4 1/4" steel
    their thick so i can have them pre machined
    Feb 2005
    Netherlands
    Wow, looks good (better!)!!
    I think you won't be dissapointed with the change of plans. This adds lot of ridgity. Big span on the y-axis though!
    May 2004
    Quote Originally Posted by erikkate View Post
    My thoughts exactly.
    I would have the gantry traverse the shorter distance, unless you absolutely need wide access to the table...
    Carlo
    Jan 2005
    the y blocks are spaced 10" apart, with rack on each side, this way i only need 1 9' rackand beam shouldn't be any swag... gonna redesign the table base using angle iron instead, this way i can drill it and screw up through my mdf base...
    I prefer the 9' open space easier to slide stuff in and out... thats gonna be one hefty y beam, i'm going to get my beams faced also
    Jan 2005
    Do you guys think 495oz steppers will be strong enough for this unit using rack and pinion & linear rails?? or should i just go with 850os servo's??
    Jan 2005
    Ok so i will be driving the x axis with a 850oz servo with 500cpr encoder and a 3 to 1 reduction, i will be running a 1/2" drive shaft accross the gantry so i can use 1 motor, the shaft will also act as a pivot point for tensioning the pinion against the rack, the right side will have the motor mounted, not sure yet if i will mount it on my gear reduction or an extra steel bracket from the gantry for weight reasons....
    May 2006
    Just a couple of thoughts. Not criticisms.
    1/2" shaft won't do the trick. Not torsionaly stiff enough over that length.
    Try to get the shaft mounted as low as you can on the gantry.
    It is desirable to have the pivot point as close to the same plane as the racks as possible.
    Certainly don't go above 45 degrees. Less is better. Zero is ideal, though you can't do that in this case.
    Keep it up, Greg
    Jan 2005
    Quote Originally Posted by Greolt View Post
    only want to build it once, thats why i'm posting
    was thinking of using 1/2" cold rolled or maybee drill rod if it comes in that size, there is a bearing on the back gantry supporting it every 18"
    Keep it up, Greg
    I think i can drop it another inch, I will be spring loading the drive but am wondering what may happen on direction change...
    I'm figuring this may be a better solution than trying to tune 2 servo's
  • Page 1 of 10 1234 ... LastLast
    1. G Code Variances from machine to machine?
      By Miguel Gonzalez in forum G-Code Programing
      Last Post: 03-28-2007, 04:31 AM
    2. Mach 2 on old machine = great machine
      By foamcutter in forum Machines running Mach Software
      Last Post: 12-16-2005, 01:11 PM
    3. Getting work(gcode) from machine a to machine b
      By strat in forum DIY CNC Router Table Machines
      Last Post: 07-07-2005, 03:13 PM
