Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 04-29-2007, 06:39 AM
Matty Zee is on a distinguished road
Smile Another Aussie Router build
Hi All,
Well, i started building my router. I plan on having a cutting travel of 1400mm x 650mm x 100mm. The Y gantry and Z axis will be made from Aluminium 3mm sheet folded to add strength and the X axis table will be made from steel.
Here are some pics of progress so far.
Name:	2007-04-28 027 sm.JPG‎
ID:	36438   Click image for larger version
Name:	2007-04-28 028 sm.JPG‎
ID:	36442   Click image for larger version
Name:	2007-04-28 029 sm.JPG‎
ID:	36443   Click image for larger version
Name:	2007-04-28 030 sm.JPG‎
Old 04-29-2007, 06:47 AM
It may be a bit hard to see from the photos. The gantry is made from 5 parts.
2 sides, 1 base, 1 front, 1 back (not attached in photo).
All parts have at least one fold in them to add stiffness and the parts are bolted together (to allow for adjustment). Only a few bolts are used to hold it together as shown.
When fully bolted together the gantry is VERY stiff. I am very happy with it so far.
Rails are 15 series SKF linear bearings.
Ball Screws are NOOK from HomeShopCNC.
Old 04-29-2007, 06:36 PM
Greolt is on a distinguished road
Good start there Matty Zee.
Keep the reports and pics coming as you progress.
Greg
Old 04-29-2007, 07:42 PM
Rodm1954 is on a distinguished road
A lot of thought has gone into your design. Nice work and keep them coming.
cheers,
Rod
Perth, Western Australia
Old 04-30-2007, 04:05 AM
crocky's Avatar
crocky is on a distinguished road
Hi Matty,
Lookin' good and it should be a useful tool when you finish. Good quality parts too.
Bob
Old 04-30-2007, 05:47 AM
epineh is on a distinguished road
Nice work, keep the pics coming.
Russell.
Old 04-30-2007, 06:52 AM
Heh Heh You've bought all the Aussies out of the woodwork haven't you
Old 06-23-2007, 07:51 AM
progress...slowly...
Hi All,
Thanks for the positive comments. I have been slowly making progress. And its only going to get harder in the next few weeks as my wife and I are expecting our first baby...
But here a couple of photos showing some progress on the z axis...
Name:	2007-06-23 012sm.JPG‎
ID:	39516   Click image for larger version
Name:	2007-06-23 010sm.JPG‎
ID:	39517   Click image for larger version
Name:	2007-06-23 011sm.JPG‎
Old 06-23-2007, 08:07 AM
Hi Matty
Neat work. Is that a Milwaulkee die grinder? I'm waiting to see what is in the THK box in the background.
Hope all goes well with the expectant one.
cheers,
Rod
Old 06-24-2007, 05:32 AM
Hi Rod,
Yep, certainly is a Milwaukee... the DG30QE if i'm not mistaken...Have you used this one? How have you found it?
Unfortunately the THK box doesn't have anything more in it that wasn't already shown in the first photos :-( still need to buy my x axis rails...
Hopefully i'll have some pics of my power supply and control box later in the week.
Cheers
Matt
  #11   Ban this user!
Old 06-24-2007, 05:40 AM
Some brighter photos of the gantry
Here are some better photos of the gantry. The first ones were a bit dark.
Also shown are some 7/8" nuts that were bought and machined out to 15/16"-16 to suit the nook ball nuts. The two nuts on the left are as-bought, the one on the right has the thread machined out and the one lying down has been parted of the make a thin nut. I will be using two non-preload nuts per axis with the ability to adjust/remove the backlash.
Name:	2007-06-23 007sm.JPG‎
ID:	39563   Click image for larger version
Name:	2007-06-23 008sm.JPG‎
ID:	39564   Click image for larger version
Name:	2007-06-23 005sm.JPG‎
ID:	39565   Click image for larger version
Name:	2007-06-23 006sm.JPG‎
  #12   Ban this user!
Old 06-24-2007, 05:43 AM
Hi Matty
The Milwaukee is a good unit. I have one with about 100 hours on it and I am very pleased. A fellow CNC'er in Perth got over 500 hours before having to replace the brushes. I sure you will not be disappointed.
Look forward to your next installment.
cheers,
Rod
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
Another Aussie homebuilt router Greolt CNC Wood Router Project Log 119 05-08-2010 05:14 PM
Bobs Aussie ITEM Router Table Build crocky CNC Wood Router Project Log 152 04-18-2009 04:02 AM
Which Aussie wants to sell me a router table Esmae Australia, New Zealand Club house 0 10-28-2006 07:08 PM
