Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 04-26-2007, 03:46 AM
edmond is on a distinguished road
Smile Lionclaw Router Buildup in South Africa
Hi all.
I am starting my buildup on a Lionclaw LC50 CNC Router.I have ordered the pipe, bearings and a HobbyCNC driver board that I am picking up today.I have drawn up all the parts from the E drawings file Andy provided, they are in DXF format.Has anyone built this machine.
Old 04-27-2007, 06:17 AM
My HobbyCNC Driver Board arrived yesterday, so I spent this morning soldering it together everything went smoothly, it realy is a nice kit.Still busy laying out and modifing some of the parts to metric sizes.Im on a really tight budget with this buildup so its going to take a good few months.Im going to order the necessary bearings and Z axis linear bearings next week from VXB and hopefully collect the pipe next week as well.
Old 05-02-2007, 01:07 PM
BobLWeiss is on a distinguished road
I built one a couple of months ago. I didn't have access to a CNC machine at the time so I cut the parts out using woodworking tools in my shop. I can tell you that I am very pleased with the machine and the design is awesome!
Good luck with yours.
Bob
Old 05-03-2007, 12:24 AM
Hi Bob
What materials do you cut on your lionclaw machine, would it be suitable for some light aluminium cutting.I am battling to get Birch Veneer Plywood here in South Africa what else can I use in its place.I ordered the bearings for the leadscrews and some linear bearing bushings for the z axis on monday from VXB.com they are so much cheaper than buying them locally.
Thanks for the encouragement
Edmond
Old 05-03-2007, 07:22 AM
Hello Edmond,
I used 1/2" MDF and 1/2" Birch Plywood. Its easy to get here at Home Depot but not sure how easy it is for you. See if you can get MDF. That would work just fine.
Yes, the machine will handle light aluminum work as long as your router is good enough and you have the right bits.
Post some pictures as you go...its nice to see other people's builds.
Bob
Old 05-03-2007, 08:38 AM
Thumbs up
Hi Bob
Thanks I will use 12mm MDF, I can get 15mm Birch Plywood but its expensive and I would have to modify all the drawings.I plan on using a 1.25 hp router to begin with until I can afford a 3.25hp Porter Cable Router Motor.Will post the pics as soon as I get going.Im going to try get the MDF this weekend.Im going to cut everything on a Multicam CNC Router at my work so that will make life easier.I plan on cutting wood, acrylic and aluminium on this machine.
Edmond
Old 05-08-2007, 12:12 AM
I bought all the nuts and bolts this past weekend for my buildup, still need to get some threaded rod in 2m lengths, I will have to special order it as 1m lengths are the standard length in South Africa.The Black gas pipe is arriving today, I actually managed to locate it in the 21.3mm and 33.7mm sizes locally here.My bearings should be arriving next week.I will be getting the wood at the end of the month, my finances are a bit low at the moment.Will post pics as soon as my buildup starts.
Cheers
Edmond
Old 05-12-2007, 08:35 AM
The black pipe arrived on wednesday, still must trim it to size.I also got the rest of the fasteners and some HDPE, PVC and Acetal offcuts from a friend who works at a engineering plastics retailer.I need to make some anti backlash nuts, does anyone have a good design for some ABN. I can cut them out of acetal and use a homemade tap to thread them and incorporate some kind of spring into them maybe. I can only found 12mm ACME Rod with a 3mm pitch locally, its expensive about $50 a metre.Also what couplings can I use for the motor to leadscrew connections I can get Lovejoy couplings here but they work out to about $45 a coupling.Can I make some couplings out of Acetal rather.Also can I use 12mm French Marine Plywood its made out of Okoume wood, I can't find any 12mm Birch Ply locally and I dont want to use MDF.
Edmond
Old 05-17-2007, 12:04 AM
Yesterday I cut some of the motor spacers and bearing supports at work on a Multicam CNC Router, I used 12mm clear cast perspex.My bearings have arrived at the post office will fetch them after work on friday.I still need som info on how to make the Anti Backlash Nuts.
Edmond
Old 05-17-2007, 09:25 AM
tajord is on a distinguished road
what speeds and feed rate di you use on that perspex, do you get and melting?
  #11   Ban this user!
Old 05-17-2007, 09:55 AM
I used a single flute 6mm carbide cutter running at 18000 rpm and 50mm/sec feed with 3 passes.No melting problems as the Multicam CNC Router has a mister unit, so I use water in it when I cut plastics.They cut with a very good finish providing you use water
Edmond
  #12   Ban this user!
Old 05-18-2007, 04:54 AM
Thanks for the info, only prob is, i have a jgro and i can't use water with that seeing it is made of MDF, but it's good to know still in any event.
My first Router / Plasma Table Buildup... InventIt DIY-CNC Router Table Machines 88 01-04-2009 10:20 PM
Shipping to Soth Africa? sixpence 80/20, TSLOTS and other Aluminum Framing Systems 2 10-20-2008 01:17 PM
A Lionclaw build (kit) BMG CNC Wood Router Project Log 28 12-18-2007 10:20 PM
Mentor for cnc router Needed in South of France (Avignon) jb84fr Mentors & Apprentice Locator 1 09-10-2007 06:52 AM
Jgro in South Africa edmond JGRO Router Table Design 5 04-26-2007 03:21 AM
