| CNC Wood Router Project Log Post your CNC machine building log here only. |
hi all, been lurkin' for a while , and decided to post i've made a router table thats a mishmash of all i've seen here and what i could get locally. i'll try to post pics in the following post using a rotozip 30,000 rpm ( neeed to slow it down) my guides cost $70 from a junkyard ( wish they were longer ) steppers are 126 oz/in from deepgroove drivers are from PMinmo ( great guy) registered mach 3 ( planning on building better machines) using allthread with the long nuts you can get for them, (need to change this.) and 3 computer power supplys hooked together to give me 29 volts ( max the A3977 can take is 35 volts) anyways i have 25 IPM, cutting at 12ipm , not bad for a first machine.. dan ps heres a test pic |
| heres those pictures... the test pic was taken of my front yard here in TN the table area i can cut is 12"x12" i've got the plywood stacked so i can take some away if i have taller stuff to cut. i'll take a breather now, and then probally use this one to make a jgro router... just wish those guides were longer, they are sweet... btw.. i have a woodmiser sawmill and 60 acres of woods, so getting wood to cut is not a problem... just cant make plywood yet dan |
Wish I had my own sawmill, timber here is sooo expensive, but mainly because we import nearly everything. A bad thing about being a little island in t'atlantic. And a lot of our native hardwood forests are long gone, cut down hundreds of years ago.... |
i look around me, and a lot of the woods have been clearcut or all the good trees taken, mostly red oaks and white in this area. I feel that we, at least in this area are going the same way. most of the time the loggers are just interested in the 2-3 cuts off the main trunk, whereas the ones i get i try to use it all, down to cutting the tops for pallet stock ( 4x6, 6x6) if you go into lowes or other box stores and look at a red oak board, it might be $50 for a lil 12" by 6 foot.. my best prices when i sell are $1 per boardfoot just dont know where the difference is. i'm found that red maple is a excellent wood to machine on mill, with aromatic red cedar not far behind.. but red or white oak, small bits want to follow the grain. will have to try out some popular and walnut. only have blowdowns for walnut thou. dan |
#10
Nice looking place sawmiller
__________________ Keith |
#11
| That is awesome! I've always wanted a sawmill, think of all the things you could make! you could make anything! How do you season the wood please?
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
#12
start with cement blocks and 4x4's to make a platform 1 foot off the ground, supported every 4 foot, then horizontal green (fresh) boards,laid down 1 finger apart for air flow, then a layer of dried 1"x1" x4' stacking sticks 2 foot apart perpendicular, then another layer of green, then a layer of sticks so on and so forth, just keep the sticks centered over each other... let dry for a year/inch thick if outside gets down to 12% locally. dan ps back on subject.... who's got the best cnc plan for like a 4 foot x 4 foot area ? or a 2 foot wide that you can pass thru ? i'd like to turn this cnc rig into something that i can make some large signs with. thanks dan |
| V4 coming up | balsaman | Steam Engines | 26 | 08-08-2011 03:38 PM |
| using MPost - now I'm no longer a lurker ;) | tnik | Surfcam | 7 | 01-31-2007 09:26 AM |
| New UK distributor coming soon?? | Strelitzia | Laser Engraving & Cutting Machines | 13 | 11-14-2006 04:37 PM |
| Is gecko coming out with a | CNCadmin | Gecko Drives | 3 | 03-03-2005 08:36 PM |
| Longtime lurker, first post | jleiwig | DIY-CNC Router Table Machines | 1 | 11-16-2003 08:03 AM |
