Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 03-26-2007, 10:08 PM
eloid is on a distinguished road
sold work vs solid edge?
sold work vs solid edge?Is it the same company can the the file swork with each other....im thinking of using a package to design 3d model, very fimualiar with autocad but have older version no 3d stuff
want some feed back which is easy to use and more powerful feature set for software modeling
Old 03-27-2007, 10:15 AM
Moderator
JerryFlyGuy is on a distinguished road
I've never used SolidEdge, however I do believe that SW & SE are very similar packages. Not to make it into a this vs that thread, but I've used SW for 4 [working on the 5th] years and LOVE the software, I've never came up against something that couldn't be modeled one way or the other. My vote would be for SW, but of course, I'm biased
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
Old 03-27-2007, 10:59 AM
rustamd is on a distinguished road
I have used SW before and it was very easy to use and learn. Also tried AutoCAD and gave up two days later
Old 03-27-2007, 03:22 PM
svenakela is on a distinguished road
The difference between SE and SW is the way you're supposed to use them and the functionality available. Actually, the 3D-engine is the same in both programs (as one buys the kernel from the other's owner...).
I like SE, my brother like SW. I see it as a matter of taste.
Regards,
Sven
Old 03-27-2007, 07:29 PM
where do u get licences for them buy online? Inever seen then in the computer stores?
Old 03-27-2007, 07:32 PM
ger21's Avatar
Most computer stores don't carry $5000 software. Contact your local reseller.
http://www.solidworks.com/pages/prog...e/phoneme.html
Old 03-28-2007, 07:17 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Could you imagine trying to get tech support or training from Business Depot he he he
www.integratedmechanical.ca
Old 03-28-2007, 05:25 PM
animation in solid works or solidedge?
can both pages do anaimation or design simulation to prove concepts?
how easy it to do with these pages looking to buy one or the other looking for good feedback
Old 03-28-2007, 05:45 PM
Moderator
I'm not sure about SE, but SW can do animated/rendered video's as well as motion simulation to some extent, it can also do alot more indepth motion simulation and FEA work if you buy the "Premium" version of the software, as well as piping/electrical/hydraulic routing etc.
Jerry
JerryFlyGuy
Old 03-29-2007, 08:59 AM
DareBee's Avatar
SW mechanical motion is now "smart" enough that it will recognize solids and apply motion without having to specify pivot points or whatever.
Example. You can model a chain link. Create an assembly of a multi link chain. In simulation mode you can grab 1 link and the others act/stay attched just like a real chain.
NOTE you need huge computing power to work with this type of "free form" sim.
You can also apply mass with gravity or spring pressure or..........
Old 03-29-2007, 09:45 AM
Moderator
Hey DareBee, are you running Premium? I assume your talking about CosmosMotion? I've just [on Monday] got the approval from management to upgrade to Premium, our primary reason was CosmosDesigner and Routing while "Motion" was just an added benifit.
Jerry
JerryFlyGuy
Old 03-29-2007, 10:35 AM
DareBee's Avatar
Actually no
I have Office Pro.
But in the "move components" dialogue use "physical dynamics" mode (make a couple of balls and push them around on a planar surface).
You can drag around free moving mechanical assemblies and see how they relate (works really well for figuring cylinder stroke lengths and pivot points).
I use the interference detection feature frequently as well.
The spring, gravity, cam follower stuff is all part of the standard SW Simulation toolbar items.
Have you tried the NEW belt/chain stuff yet?
Observations?
Sounds good but a haven't had the time or need to play with that feature yet.
graphics in solid Edge Rob 1264 SolidEdge 10 11-26-2007 05:43 AM
Academic Solid Edge - limitations?? andy_ck87028 SolidEdge 5 02-08-2007 03:35 AM
Solid Edge 2D is now free bob1371 General CAM Discussion 0 09-12-2006 03:52 PM
Corner rounding on 1 edge of solid cube Pat BobCad-Cam 3 06-27-2005 01:44 PM
Which came first, Solid Edge or Solid Works? Arnie General CAM Discussion 3 09-15-2004 06:25 AM
