Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 03-24-2007, 11:12 AM
alwaysready is on a distinguished road
Chris's build log of Hack's 80/20 router ( 2'x4')
OK im going to start off with info about myself here.
I am a licensed electrician/commercial developer/ vinyl signmaker when needed/ and all around DIYer.
I have 0 CNC experiance except for my vinyl cutter for doing signs.
My father has a mill and 2 lathes 1 small 1 big ( 24" swing 6' bed)
and i have a small lathe i recently aquired hot wired it to work but never really used it yet( no need). so i can look to dad for milling lathe info..
I am using Hack's Plans found here
http://studysession.com/cnc/8020-CNCRoutercad.pdf
They are designed to use the 80/20 bearings and has a 2'x3' cutting area. I'm Going to stretch the x? out to 4' to make a 2'x4' table.
im thinking of using it for making signs in foam wood and acrylics.
Maybe some other uses.(this is a toy) this will not be for production use. as i dont do anything production really my vinyl cutter gets use 2-3 times a month. Well lets begin..
Old 03-24-2007, 11:23 AM
I am going to keep track of all my pricing here..
i am including shipping wherever possible.
hitachi router
$115.00shipped
80/20 surplus rails, bearings, and T-nuts
$717.40 shipped
Wood Kit from Hack
$70.00 shipped
Mcmaster - threaded rod, delrin, nuts, Bearings, aluminum angle.
$194.44 shipped
Total so far..
$1096.84 add the xylotex kit and i should be around 1600 about..
remeber i also bought things to make it easier for me it could have easily cost less.
like waiting and buying the standard 80/20 bearings. buy used pieces of 8020
buying a used/refurb router, you could build your own drivers and buy ebay motors.. etc.
Old 03-24-2007, 11:24 AM
Router
well start off with the router. I purchased the CNCzone typical easily purchased / found locally Hitachi model M12vc from amazon
http://www.amazon.com/Hitachi-M12VC-...4752901&sr=8-3
Hitachi Router $115.00
Old 03-24-2007, 11:30 AM
8020 Rails and Bearings from 80/20 surplus on EBAY
8020 T Slot Aluminum Extrusion 15 S 1530 x 18
For the Z axis
8020 T Slot Aluminum Extrusion 15 S 1530 x 96.50 -1T
Will be cut into 2 pieces for the X and Y axis
8020 T Slot Aluminum Linear Bearing 15 S 6836
8020 T Slot Aluminum Linear Bearing 15 S 6824
8020 T Slot Aluminum Linear Bearing 15 S 6835
by the way i used the 683 series bearings which are the high cycle bearings, only because that is what 8020 surplus had in stock at the time.
the 682 series is the standard bearing(and a little less $$$)
$697.50 (shipped)
T Nuts (forgot with original order)
$25.00 (shipped)
Thanks goes out to Mark Meyer at 8020 surplus for prompt emails to ?'s and other help i recieved..
Old 03-25-2007, 05:38 PM
crocky's Avatar
crocky is on a distinguished road
The build is going along great, keep up the good work
Cheers,
Bob
Old 03-25-2007, 08:40 PM
Moderator
bp092 is on a distinguished road
cool machine, and a really well documented PDF, love the renderings, must help a lot in assembly, look forward to seeing your finished machine
Old 03-26-2007, 09:12 PM
mcmaster.com
1 Each 98910A033 Plain Steel Threaded Rod 1/2"-13 Thread, 6' Length $3.99 $3.99
1 Pack 90630A125 Grade 8 Plain Steel Hex Nylon-Insert Locknut 1/2"-13 Screw Size, 3/4" Width, 19/32" Height, Packs of 10 (Same as 90630A888) $4.57 $4.57
1 Each 9721K31 UHMW Polyethylene Precision-Ground Blank 1/2" Thick, 2" X 12" $3.62 $3.62
6 Each 6384K361 Steel Ball Bearing Flanged Double Sealed for 1/2" Shaft Dia, 1-1/8" OD $8.08 $48.48
3 Each 59985K19 Hi-Offset Slotted-Disc Set-Screw Coupling Hub 1/2" Bore, 1" Outside Diameter (Same as 59985K3) $9.72 $29.16
3 Each 59985K17 Hi-Offset Slotted-Disc Set-Screw Coupling Hub 1/4" Bore, 1" Outside Diameter (Same as 59985K3) $9.72 $29.16
3 Each 59985K63 Acetal Coupling Disc for 1" Outside Diameter Hi-Offset Slotted-Disc Set-Screw Coupling Hub $3.17 $9.51
1 Each 98837A033 Plain Steel Threaded Rod 1/2"-13 Thread, 3' Length $2.88 $2.88
1 Each 8982K374 Alloy 6061 Aluminum 90 Degree Angle 1/4" Thick, 2-1/2" X 2-1/2" Leg, 4' Length (Same as 8982K37) $34.23 $34.23
Merchandise Total $165.60
toatal with shipping and tax $194.44
Yes Hack did a very nice assembly manual one of the reason i went with this design, and from the illistrations i could see the pure simplicity of the design.. Thakns Guys
Old 03-27-2007, 08:30 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Yes Hack did a very nice assembly manual one of the reason i went with this design, that and from the illistrations i could see the pure simplicity of the design.. Thakns Guys
Is there a reason you are going with standard threaded rod instead of an acme thread, which will five you faster rapids and more torque?
Joe
Old 03-31-2007, 04:47 PM
i started a discussion about the lead screw here.
http://www.cnczone.com/forums/showth...403#post279403
Im going to get the machine up and running on threaded rod then turn it over to acme rod, it looks like..
Old 06-28-2008, 07:16 AM
nwc-cnc is on a distinguished road
watching & learning.....
i am watching and learning.......
  #11   Ban this user!
Old 10-15-2008, 03:21 AM
wizardrule's Avatar
wizardrule is on a distinguished road
what ever happened with this project?
  #12   Ban this user!
Old 10-15-2008, 03:36 AM
joeybagadonuts's Avatar
joeybagadonuts is on a distinguished road
Smile
Looks like he might have run out of dough.
JoeyB
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
1st cnc router build ajl6549 DIY-CNC Router Table Machines 1 11-02-2006 11:47 AM
I want to build/buy a cnc router bp092 DIY-CNC Router Table Machines 8 10-27-2006 08:39 PM
Build Log - hack's plan bryanrabb DIY-CNC Router Table Machines 6 03-23-2006 09:57 AM
