| CNC Wood Router Project Log Post your CNC machine building log here only. |
My CNC router is pretty much up and going. (just gotta get a better spindle) However you pretty soon realise that securing material to the table is a whole new can of worms. Screw it down. Clamps don't reach far from the edge. Double sided tape. There has to be a better way. ![]() I'm going to have a go at making a vacuum hold down thingy. I had a piece of acrylic (I think that's what it's called) 20mm thick that someone gave me. A bit beaten up but OK. Got some quarter inch rubber stuff. Sort of foam rubber with an external skin. Drew up a grid pattern in my cad program. 30mm squares with 3mm radius on the corners. 5.25mm channels in between. Generated a toolpath in sheetcam. Didn't know how hard to push the 1/8th endmill I had. So I went 1000mm per min. RPM? About half speed on the cheapy little router that is my temp spindle. Sounds like it's about to explode if I go faster. ![]() 1mm depth of cut. Could have gone deeper I think but I did not want to break the only little end mill I had seeing it was the weekend and couldn't get another. ![]() Set my machine going and went and watched TV. Took about 90 mins. |
| Drilled an inlet. Maybe that should be called an outlet. ![]() Fitted a quick release air coupling. Have no vacuum pump yet. I want to see how well this works before splashing out the hard earned on one of those. ![]() So I pressed the little shop compressor into service. Connected up the hose to the inlet side just to see what will happen. ![]() Well it worked @#&%* brilliantly. No way that piece of board was going anywhere.Sucked it down like you wouldn't believe. Well a lot of you would of course as you've had plenty of experience with vacuum tables. ![]() Now where am I going to get one of those nifty little vacuum pumps like they have in the US ????? . |
| Yeah I am thinking about that Geof. They can be had quite cheaply here. I thought I could reverse the head and hook it up permanently that way. Have to replace the presure switch with a vacuum type and guage as well. Then you would have a all in one unit with a good size reservoir. Don't see why it would not last just as well as when it is compressing. It's real noisy though. ![]() A silencer on the air out port would maybe help a little bit. Greg |
| You are aware of this site? http://www.joewoodworker.com/veneering/welcome.htm He has a whole thing about vacuum press and pumps you build. |
| Had a look at that Sailfl. Good site. Lots of info. Unfortunately the most important or at least the most expensive part is the pump. We have different voltage here in Aus. And changing our dollars to yours then paying freight makes things very pricey. |
| Not sure what the shipping would be, but you can get a 220V pump from www.surpluscenter.com for $89 US. I just got one the other day.
#10
What are you using it for? Do you think it will keep up with vacuum clamping as above? I remember they used to slow to a crawl when you put your foot down and go like the clappers as you eased off. |
#11
Make sure you are sitting down when you get the shipping price. That is if they will give you one. We ship metal parts to Sydney (Allambie Heights) and it costs a few penneis. |
#12
| It was $17 to ship to Detroit, probably at least $75 to ship to you. I should also mention that although they are advertised as new, mine was a bit banged up. Consider them "unused". They are not in any factory packaging, so may be dented a little. Mine does work fine, though. Anyway, I'm going to use it for both veneering and a hold down system, whenever I finally get my router done. I was already using a Joe Woodworker venturi setup, but it puts a strain on my compressor. I'm going to set it up just like the JoeWoodworker system. I hooked up the Gast pump to my reservoir in place of the venturi, and it pulled 26"Hg pretty quickly. If you get a very good seal, it should work just fine. The Joewoodworker site has a small section on clamping, and he uses the same system as for veneering. http://www.joewoodworker.com/veneeri...umclamping.htm At work today I was making a new set of vacuum pods for our router. If I get a chance this week, I'll try to make a small clamping jig to try with the new pump. For good quality gasket material, check out www.allstaradhesives.com
| Vacuum table and vacuum pump | garagefela | DIY-CNC Router Table Machines | 19 | 01-25-2012 10:30 AM |
| LatheMaster 9 X30 CNC Adventure | Ron111 | Mini Lathe | 97 | 10-10-2008 09:51 AM |
| Questions for vacuum clamping | InsaneEPP | DIY-CNC Router Table Machines | 15 | 02-20-2008 07:28 PM |
| pipe clamping | larry53 | Welding, Brazing, Soldering, Sealing | 6 | 04-09-2007 07:41 PM |
| Clamping Pressure | Team Pierson | Work Fixtures and Hold-Down Solutions | 7 | 02-12-2007 01:08 PM |
