| CNC Wood Router Project Log Post your CNC machine building log here only. |
| http://www.amanatool.com/cncroutingdetails/rc-4000.html 5900F,6000F and 5900G, 6000G are almost exact to your photo http://www.whitesiderouterbits.com/catalog.html https://www.onsrud.com/oc/pdf/2006MDFPanel-DoorBit.pdf And onsrud has panel/mdf cutter inserts for cnc designed bits |
| Looks like you got your sample pics from www.eagle-america.com Why not buy from them? I buy a lot of my bits from them. They also have a cheaper line at http://pricecutter.com/product.asp?pn=P15-3918&c2p=dd
does anyone have a router or spindle that of handle this kind of bits http://www.amanatool.com/industrial/routing.pdf also looking for idea for a diy spindle, maybe a 5ph 120v motor driving a nice custom made belt drive spindle that can handle these bits was thinking of get a heavy duty shaft made up by machine shop with a gear box ? |
| You posted a IMG link to the file source on your desktop, you need to upload it or provide the original link. Maybe ger might have some rec's on spindles like var. speed routers that accept 3/4 collets so I posted what you emailed me in response below. All of the routers I've seen even 3hp are 1/2" collets.
looking for the best deal...lol need to save for more $ for toys for my cnc project lol |
| I wouldn't skimp on tooling, your toys won't make a difference anyway you build them, you can add anything to the machine if you have cheap tooling then you still won't have a good end product.. and if you're looking on the cheaper side forget onsrud and amana, maybe whiteside, but I wouldn't go too cheap.. these bits don't cost that much in relative to what they put out and how long they will last |
| Amana makes a single edge bit like the first one in that catalog with a 1/2" shank. We use it at work. RC 1154 http://www.amanatool.com/cncroutingdetails/rc-1154.html We also have one of those Infinity raised panel bits. It costs more than a 3HP router, and weighs about 5 pounds. It's very, very big. Any of those Amana tools need a serious spindle. About $2K minimum. The cheapest you'll probably find would be here. http://www.ekstromcarlson.com/router_packages.htm
| Actually, most of the bits in that .pdf cost more than a 3HP router.
#11
| Check with www.vortextool.com I've had them make us some custom bits in the past.
| Yet again about router bits. | Konstantin | WoodWorking | 5 | 12-08-2006 09:31 PM |
| Good source for wood bits | Art Ransom | WoodWorking | 2 | 10-12-2006 11:00 PM |
| What bits to use | becikeja | WoodWorking | 5 | 08-11-2006 10:27 AM |
| Where to buy bits | hugo carradini | DIY-CNC Router Table Machines | 2 | 05-23-2006 06:52 AM |
| Luv those little bits.. | CRFultz | DIY-CNC Router Table Machines | 27 | 05-14-2005 05:41 AM |
