Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 02-25-2007, 12:25 PM
eloid is on a distinguished road
control spindle for 2.5-3 hp router
Has any used or found a way to control the spindle speed via, mach 3 and
break out board and some kind of servo motor to a Router Speed Control box?
Old 02-25-2007, 02:43 PM
ger21's Avatar
You could mount a small stepper to the speed control to turn the dial.
Old 02-25-2007, 03:40 PM
CNCRob's Avatar
Moderator
CNCRob is on a distinguished road
Thats something I have thought about doing. Has anyone ever tried this?
Robbie
Old 02-25-2007, 09:56 PM
Madclicker is on a distinguished road
Something I've thought about also. Problem is it takes a full axis away. I want to make an ATC, and to do this I figure I have to use 3 axes. 1 to move the dust shoe up and down, 1 to swing it out of the way and 1 to rotate the tools into position.
Did I read somewhere that control of big dog spindle speed is done with PWM? If so I can make a linear actuator that would use simple small dc servos and this signal.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 02-25-2007, 10:02 PM
ger21's Avatar
Use pneumatic double acting cylinders and solenoid valves. Then you just need to use maybe 2 outputs instead of axis.
Old 02-25-2007, 10:08 PM
Thanks, sometimes I can't see the obvious solution.
Steve
Old 02-25-2007, 10:11 PM
ger21's Avatar
Our toolchanger at work has each tool mounted to a cylinder that moves it under the spindle, and the dust collection brush on the tool change side is lifted by an air cylinder.
Old 02-25-2007, 10:15 PM
Very cool. I have a handicap in that I've never even seen a cnc machine before I built this "contraption". Still have never seen a "real" one in person.
Steve
wood router and spindle control eloid CNC Wood Router Project Log 0 02-21-2007 04:39 PM
Spindle control wildcat Mach Mill 7 01-22-2007 09:41 PM
Spindle Speed Control bill south Benchtop Machines 2 02-24-2006 12:27 PM
VFD to control a spindle? What do I need? Allistah Mach Software (ArtSoft software) 7 12-07-2005 09:39 AM
BP spindle speed control zcases Mach Software (ArtSoft software) 1 06-15-2005 09:06 AM
