Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 02-23-2007, 09:17 PM
eloid is on a distinguished road
Methods and apparatus for pre-planarizing cnc axises
Hope to to have all the "great cnc builder" to post how they
pre-planarizing there axis in this post, pictures are very welcome
cheers to all there hard work
Old 02-24-2007, 02:44 PM
outsider is on a distinguished road
Hi!
To build my new (420X760X180 mm) fixed gantry mill, I used a very simple methode to pre-planarize my axcises. I let by a joiner's shop cut from 19mm thick board two jigs. One for axis X and one for axis Y. These jigs had the exact measurement between the respective 25 mm dia axises. Under these jigs i fixed with screw 50 mm wider boards. Then I cut rectangle-form holes in this assemblies for positioning the alu blocks of the teflon bearings. Then I fixed the axis roads with rubber band to the jig assembly.Because the CNC saw of the joiner's shop made an exact, paralell cut and because the under board of the jig assembly did not allow the axis roads to move or fall down, I got a perfect axis assembly to fix the roads to the frame. You can modify this apparatus so, that it can position the leadscrew too.
cheers G. Merkel
(Budapest, Hungary)
Old 02-24-2007, 06:17 PM
kiwichris is on a distinguished road
I'll bite..
From the first reply, I asume 'pre-planarizing' means getting the ways lined up accurately?
(there's no such thing as a dumb question! )
Old 02-25-2007, 02:01 PM
Yes, I anderstood so. It was a big problem of the newbies of our CNC community
(www.hobbycnc.hu)
Old 02-26-2007, 09:35 PM
Method to square a Gantry?
found a nice link
http://www.cnczone.com/forums/showth...light=traverse
SIGN Making methods? esmiller General CNC (Mill and Lathe) Control Software (NC) 8 05-23-2008 10:49 AM
What methods did you use for sliding motion widgitmaster Polls 1 10-09-2007 10:46 PM
Please Help With Best Practise Methods Joey Fanuc 12 01-09-2007 12:42 PM
Precision layout methods pminmo General Metalwork Discussion 21 08-20-2005 08:21 PM
Simple CNC marking/writing apparatus? kywoodwrkr DIY-CNC Router Table Machines 16 03-03-2005 08:58 AM
