| CNC Wood Router Project Log Post your CNC machine building log here only. |
Hi To All been looking through loads of info here. blown me away.. i am looking at building my own milling machine. but the main thing is cost! as always. I have never under taken anythinglike this so its a first. I am used to using autocad both in 2d as awell as 3d (if that helps) other than that i am a novice. i am looking at routering out letters and pictures in wood. If anyone can help or guide me in the right direction, with drawings or sites. Would be very grateful |
No, you would have to get a CAM program to create the toolpath's needed to mill your part. the CAM program would create GCode and that is what the CNC controller reads to do your milling. |
| depends on what your willing to spend. there's opensourced cnc programs out there (opensourced means free for the most part) then there's the hobbyist programs (like BobCAD-CAM) which aren't that bad in price, then there's top of the line cam programs like surfcam. A quick search on google for CAM software will give you millions of hits. |
| http://home.comcast.net/~cncwoodwork.../AC2GCv039.zip Thread here: http://www.cnczone.com/forums/showthread.php?t=8226
| could anyone advise me what the basic components are that i will need besides the computor and my router. I understand that i will need to be able to move in both the x & y axis and Z. i have a design for that, and i have read peoples remarks concerning materials. what i trying to locate is a site that may show me the equipment i will need, and what plugs into what... Now i did say i was a novice |
#10
| I'd recommend downloading Joe's 2006 plans and the JGRO plans and study them Both should give you a good idea what you need. http://www.cnczone.com/modules.php?n...category&cid=2 Basically, you'll need. Machine control software (Mach3, TurboCNC) Motors (steppers or servos) Motor drives to control the motors. Leadscrews and nuts or some other means to provide motion, such as rack and pinion.
#11
| Thanks all Just been pricing up linear rails Wow not cheap. hoping to make the x axis 1200mm x 800. Not being tech minded seems very heavy trying to work out wieghts etc etc. looked at bobcam seems to suite my needs with bobart as a attachment. Their doing a deal at the moment for all the software....if anyone is interested. Big thanks to Simso in australia for your help |
| stl's or iges or dxf's for 3axis milling? | dave6 | Visual Mill | 19 | 05-30-2009 08:54 AM |
| Simple 3axis machine | zoey | Machine Problems, Solutions , Wireless DNC, serial port | 3 | 02-21-2007 12:12 PM |
| need help with tos milling machine | derkiow | General Metal Working Machines | 0 | 03-08-2006 08:06 AM |
| Why would this machine be bad for milling? | jevs | Knee Vertical Mills | 5 | 06-16-2005 10:49 PM |
| D&M Milling machine | mrand | Benchtop Machines | 1 | 03-11-2005 02:58 AM |
