Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 02-19-2007, 10:18 PM
jeffg is on a distinguished road
New Idea 4x8 Router Table
Hi Everyone I Got The Cnc Bug About Two Years Ago. After Looking At Web Sites And Ebay For A 1 1/2 YEARS I Realized I Was Not Going To Find A Good Used Or Cheep Cnc So I Bought A Stepperwold Kit And Built One. Dont Laugh At My First Monster I Built It Before I Found The Cnc Zone [had No Idea What I Was Doing] Anyhow I Came Up With This New Idea And I Think Its Going To Be Pretty Good So I Thought I Share It With You Guys. I Will Post More Pics. Along The Way. sorry i didnt have room for pics of 1st machine in this post i will put them in next one.
ID:	32119   Click image for larger version
ID:	32120   Click image for larger version
ID:	32121   Click image for larger version
ID:	32123   Click image for larger version
Old 02-19-2007, 10:22 PM
Heres Some Pics Of My 1st Monster
ID:	32125   Click image for larger version
ID:	32126   Click image for larger version
ID:	32127   Click image for larger version
Old 02-19-2007, 10:45 PM
Ok So I Got All The Alu. From 80/20 Garage Sale. I Was Very Happy With It. 6105-t5 Nice Stuff To Work With. I Used Pan Heads Counter Sunk To Bolt The Frame Together. After I Squared It Up I Had To Add A Few Shims To Make It Perfect I Will Post More Pics Tommorow
ID:	32140   Click image for larger version
ID:	32141   Click image for larger version
Old 02-20-2007, 06:02 AM
Ok Building The Bearing Blocks. The X Pieces I Used Are The Same Inserts You Use For Bolting The Frame Together They Are Threaded On Two Ends You Just Have To Cut One Ear Off {be Carefull!!!}.then When You Start Bolting Tmem Together The Side Play Adjustment Is In The Form Of Shims And Washers Top And Bottem Play Has Slots On Bottem Of Side Plates With 10/32 Socket Heads For Adjustment. Be Carefull Respect The Machine Becouse It Does Not Respect You.
ID:	32143   Click image for larger version
ID:	32144   Click image for larger version
ID:	32145   Click image for larger version
ID:	32147   Click image for larger version
Old 02-20-2007, 10:44 AM
studysession is on a distinguished road
Nice -
Where would you get lead screws that long?
Please check out my CNC blog
http://cncinside.com
Old 02-20-2007, 11:25 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I do not think leadscrews will work well for this project unless you are traveling 20ipm to avoid bad whipping, So that being said I would go for a rack and pinion system or belt drive with a min. of 2:1 reduction if not more.
Joe
Old 02-20-2007, 11:28 AM
joecnc2006's Avatar
www.joescnc.com
the only problem i see so far is the hardened steel rollers will wear on the alumn. pretty quickly and you will need to adjust the rollers a little more than usual if it was an all steal construction.
Also another note: If you add a cross piece along the bottom of the gantry side to side this will help prevent the Alumn. from tilting on the sides.
Please consider these as an opinion only and just as a help sugestion.
Joe
Old 02-20-2007, 11:44 AM
aspenelm is on a distinguished road
looks good, I hope you add a lot of bracing to the framework. Also are the bearings running on the aluminum surface? unfortunately that wont last long, but it looks like you could easily subsitute a piece of 1/4 steel plate and bolt it on to the sides.
I know what it is like to build a monster, my first running router is about 4' square cube in space, yet only cuts 28"x18"x4". Just used materials on hand and that is what resulted.
sorry, didnt see joe's post about the rollers...
Old 02-20-2007, 05:53 PM
Smile
HEY GUYS THANKS FOR LOOKING.I AM TRYING TO WORK OUT THE BRACEING AS I GO. TO ANSWER STUDYSESSION WWW.ROTON.COM HAS ALL ACME AND BALL SCREWS THEY STOCK IN 12 FT LENGTHS WILL CUT TO ORDER AND NUTS GOOD PRICES THEY CAN SHIP UPS GROUND UP TO 9 FT.I WAS THINKING ABOUT A 1"ACME WITH BRONZE NUT FOR X AND 3/4 FOR Y. MY OTHER MACHINE CUT AT A WHOPPING 12 IPM I WILL BE HAPPY IF THE NEW ONE CUTS AT 40-80 IPM THE OTHER ISSUE IS THE ALUMINUM WEARING I THOUGHT ABOUT THAT THIS STUFF FROM 80/20 IS 6015 GRADE T5 TEMPERED WHEN I CUT THE 3/8x6 FLAT STOCK ON MY CHOP BOX I WANTED TO SAND OUT THE BLADE MARKS ON THE BELT SANDER IT TOOK SOME TIME TO CLEAN THE EDGES UP BESIDES I HOPE BY THE TIME I WEAR OUT THE RAILS I FIND A GOOD DEAL ON SOME THK RAILS. HERES A PIC. A LITTLE MORE PROGRESS
Old 02-20-2007, 06:21 PM
HEY GUYS I AM GOING TO NEED SOME HELP IN THE ELECTRONICS DEPT. I WAS THINKING OF USING KELING DRIVES I AM NOT SURE WHAT STEPPERS ? MAYBE NEMA34 600oz? I BOUGHT A POWER SUPPLY ON EBAY 24v 18amp REGULATED CONTINOUS. WHAT IS THE REGULATED AND UNREGULATED?? HERE IS A PIC OF THE POWER SUPPLY. TELL ME WHAT YOU THINK??
Old 02-20-2007, 06:31 PM
ger21's Avatar
Depends on the motors and drives you choose, but you'll probably want a 36V to 48V power supply. Something about 15-20 times the motors voltage rating.
And try not to type with the caps lock on.
  #12   Ban this user!
Old 05-18-2007, 06:39 AM
Thumbs up Almost done
Hi just wanted to post some pics i am done with the build i just have to wire it up!
ID:	37510   Click image for larger version
ID:	37511   Click image for larger version
ID:	37512   Click image for larger version
New router table moreil DIY-CNC Router Table Machines 5 08-29-2006 03:45 AM
4 x 8 router table lumberjack_jeff Open Source CNC Machine Designs 3 06-02-2006 07:25 PM
Router Idea and Questions Bruggles DIY-CNC Router Table Machines 8 02-02-2006 09:08 AM
router table planescott Mechanical Calculations/Engineering Design 7 01-16-2006 12:49 AM
Your first CNC Router Table widgitmaster DIY-CNC Router Table Machines 9 12-08-2005 12:40 AM
