Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 02-12-2007, 10:44 PM
ezgoin is on a distinguished road
My Joe2006 build
Hi all,
I figured it was about time I started a thread on my build. This build will be a slow process since I'm laying out templates and using those to route the parts. So far I've managed to get all of the torsion box pieces cut, and assembled the Y axis and gantry bottom. The X axis is cut but yet to be assembled. I also have the left side of the gantry cut and glued together. The right side still needs to be glued and have the routing for the bearing block. I got carried away when I was cutting the gantry pieces and made the hole for the pipe in all 4 lol. Guess I'll find out if filling a 1" hole is as easy in wood as it is in steel
Unfortunately I haven't taken any pictures(been super busy making templates and cutting parts ). I'll dig the camera out and take some shots to post later.
Old 02-12-2007, 11:06 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Looking forward to seeing more of your post and progress..
joe
Old 02-13-2007, 10:05 PM
Didn't have much time today, but I took a couple shots to post. The first is the gantry bottom torsion box, and the second is the Y axis torsion box. I'll take more pics and post them later.
ID:	31652   Click image for larger version
Old 02-14-2007, 06:23 AM
Moderator
bp092 is on a distinguished road
Looks good, just be careful with the skins as it looks (could be wrong) like one skin is cracked out a little bit. On the X table they need to be really impeccable otherwise you will have a tough time getting the same zero on it in one place to the next. Looking forward to the rest of your build log!
Old 02-14-2007, 07:35 AM
Yeah it did. Looks like there's something that got under the skin . I realized it too late though, but since nothing will be sitting on the skin I didn't stress over it much. I understand about the X-axis needing to be flat, but wouldn't skimming the spoil board clear any inconsistencies?
Old 02-14-2007, 08:00 AM
joecnc2006's Avatar
www.joescnc.com
One thing i have thought about is having another floating table top of 1/2" material, sitting on top of 1/2" hdpe. or the 1/2" just being the spoil board.
glue the HDPE down to X-axis torsion box then use the machine to skim the tops of them, this will give you a flat and even 0 across it, then attach 1/2 mdf ontop of those via capret tape or nylon screws.
This will eliminate any improfections in youe X-Axis Torsion box.
Joe
Old 02-14-2007, 08:59 AM
Moderator
Sounds interesting joe. I actually was at home depot and saw carpet tape randomly and remembered to try it out. Man is that stuff strong! Not a good hold down as it won't hold it true but it is a great alternative to adding tabs .
Old 02-14-2007, 09:31 AM
Now that you mentioned the hdpe,I was wondering about the cutting board that people have used. Can someone give me an idea what I should look for? Or perhaps that spare corian cutting board we never use may come in handy
Old 02-14-2007, 09:34 AM
Moderator
I believe most plastic cutting boards will be made of a HDPE like material. I puchased one from home goods and need more but I think that walmart, target, any cheap retail store like that will carry them for about $10 tops. Not sure where guys were finding 3/4" cutting boards, most come in 3/8" and 1/2" that I have seen. Also some people were calling local plastics companies looking for drop or scrap that they can buy by the pound.
I'm trying to build my own cnc so... i need a little help... zet-jaro CNC Wood Router Project Log 33 08-21-2011 11:50 AM
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
Joe2006 Build dighsx Joes CNC Model 2006 256 09-15-2007 08:38 PM
I'm in... another Joe2006 machine DougO Joes CNC Model 2006 128 02-09-2007 12:49 AM
