| CNC Wood Router Project Log Post your CNC machine building log here only. |
Hi I´m a newbi to cnc and this is may first post And I´m stuned, to see the amounth off nollege from all you in here My problem is ball scews are really expensive, and extreemly expensive in danmark (europe) So I have an idea to use parts from a bi cykle these is more avelerble and a lot cheaper If I´m using a bicykle chaine and the smallest gear (the small guide gear on the back wheel gear shifter) around the gear its 13,5cm (the green ring on the drawing) and if I use 1/8 microsteping I will have a travel per step at 0,084mm I think it will be precise enough for me but will it be power full enough to do it this way ? The electronics is a Stepmasternc controller with 260 oz motors from http://www.stepmasternc.com/stepmasternc_010.htm and planning to build “joe” size routher I have no idea how fast a steper moter is turning around (RPM) and if its posible to ragulate the speed And if its is poseble to regulade the speed down, will I get more tourgh How many cm travlinging per second is idiale for cutting mdf I just saw this wire driven machine, this solution may even be better… http://video.google.com/videoplay?do...97521879&q=cnc how is the wire setup build? does any of you have an idea? Ideas and thoughts will be highly appriciated Kind regards Harvid Last edited by Harvid; 02-08-2007 at 05:11 PM. |
| Whats the most expensive part you've worked on? | Chuck Pressure | General Metalwork Discussion | 68 | 11-06-2007 01:13 PM |
| Whats the most expensive damage you've done to a machine | M@T | General CAM Discussion | 42 | 02-24-2007 11:11 AM |
| are expensive servos required? | rockfish | Commercial CNC Wood Routers | 2 | 10-11-2006 02:32 PM |
| IKO Rail Scews?! | dbtoutfit | DIY-CNC Router Table Machines | 2 | 08-18-2006 01:22 PM |
| Stop Buying Expensive EDM Pinch Rollers | Jim Abbett | Product Announcements & Manufacturer News | 0 | 09-29-2004 03:51 PM |
