| CNC Wood Router Project Log Post your CNC machine building log here only. |
#13
| Hey, i am building the same route(in aluminum). i'm use 4"x24x1/2 for base 17x4-1/2x3/4 for 2 sides bearings link acme leadscrew, oil harden rod from enco planning to spend less than $800 i'll try to post some picture when i get all parts togather good lurk on your machine Last edited by ezland00; 03-01-2004 at 08:06 PM. |
#15
| Cold, Better. But you still have a bullet to bite... Need to add at least ONE more linear bearing to the y. I'd put it on the bottom shaft(nearest the cutter) to decrease deflection. Raise the black frame supports ands they will add support for your table. Definitely need a cross brace between the gantry uprights... Hope this helps, Ballendo P.S. I think you may later "wish" your steppers were larger. 3210 will work, but is a bit on the small side if you're planning for any kind of fast traverse speed.
#17
| Hey Cold fusion, Now thats a familiar setup! Great work on the CAD drawings. Think your gantry will probably come out lighter than 60lbs. I have -lots- of steel where alu could be used, for instance in the bearing blocks and Z-assembly, and that gives around 60lbs.About the double bearings: What accuracy are you aiming at? Mine has double bearings in a single block, 16cm (6.25") wide, giving up to 0.5mm (0.02") gantry skewing in both directions when pushed fairly hard. If thats too much for you and you're not willing to give up travel think about dual leadscrews? Good luck, John |
#18
| Cold, another thought. You probably don't need as large a stepper motor on the Z axis. I would think that 100 oz-in would be fine. This might allow you to offset some costs for the additional linear bearings. T |
#19
| Ok, things just swung 180 degrees. I am now the proud owner of 4 30 inch Thk rails. Here is the auction I won. http://cgi.ebay.com/ws/eBayISAPI.dll...category=42899
__________________ Proud owner of a Series II Bridgeport. |
#21
| Hager..."Now for the best way to utilize them" how about on a CNC machine? HAHAHAHAHAHAHA (sorry, couldn't resist!)
__________________ Stop talking about it and do it already!!!!! (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#23
| "Now for the best way to utilize them" The tips have started to come in. These bearings are small and strong, and require different mounts and save a lot of space over the "rail bearings" Good luck, now let's see some new drawings. Hager |
#24
| Here are pics of the latest cad. The red and grey square stock is 1.75 inch aluminum , the green sides are .5 inch, and the red end plates are .375 inch. The pockets in the gauntry are for extrusion, which has not been added yet. Tomorrow I'll get the ball screws in along with the cross gauntry brace.
| Building a CNC router | HomeCNC | CNC Wood Router Project Log | 230 | 10-18-2009 07:56 AM |
| purchase or building a home cnc router. | s_bedow | DIY-CNC Router Table Machines | 9 | 03-19-2005 01:22 AM |
| Books on building CNC Router? | samualt | DIY-CNC Router Table Machines | 9 | 08-06-2004 08:48 AM |
| My first CNC router: 1.5 years building | hddjohns | DIY-CNC Router Table Machines | 2 | 04-03-2004 11:18 AM |
| Got a jump start on building materials for my CNC Router | Darren_T | DIY-CNC Router Table Machines | 3 | 11-16-2003 08:13 PM |
