Good luck on your build. If you just follow the manual step by step you shouldn't have any problems. One of the best manuals I have seen. It's a nice little machine also. Your final figure is higher than mine turned out including me buying Vcarve Pro and Mach3. Hopefully yours will turn out cheaper also. Looking forward to seeing a lot of pictures.
LinkBack URL
About LinkBacks
