I wanted to post a build log but I didn't have a camera to share pictures and all the plans were just in my head. After using it for the last 6 months or so I have learned a lot about the weak design but have been able to use it knowing what I can and can't do.
To begin I didn't have any tools other then a set of Ridgid cordless power tools (a drill, sawsall, and skillsaw) oh and a $20 trim router from Harbor freight last an old $10 skill saw from the flemarket. I knew to pull this off I would need a table saw, drill press and router table so I made all those things by building jigs that use the Ridgid tools. For example an old dresser made a great table saw with the old $10 skillsaw mounted underneath and using the dresser top as the table and screwing a fence in the position I needed. On both X rails (the length rails) and the Y rail (side to side) are just 3/4" mdf cut in 6" strips with a 1/4"X1/4" slot cut in the side ends for the 1/2" precision ground steel rods to lay in.
The table size is 48"X24" with about 5" of Z travel (depending on how I place the router and what bit I use). I'm using 3 Geko 201's powered by a 50 volt transformer I got out of an old high power audio amp (about 10 amps?) driving 1 nema 34 604oz for the x and 2 nema 34 ???Oz for the x and y, the 5 volt is still on a breadboard. I'm using 1/2" rolled ball screws on all x, y and z but the end connected to the couplers is ground on a grinder freehand and not so straight.
The machine performs very well, it will run 170 ipm but cutting around 80 or so is as fast as you would want on most any wood. It has good repeatability and a resolution of 1/10,000" but the design really won't allow that close of work with any accuracy.
Now I need to figure out the image part. I got a camera today and have taken some pics of the machine and some of the work I have done on it.
I will post pics shortly
