Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 08-18-2006, 01:51 PM
richaevans is on a distinguished road
getting started
hi all.
I am in the planning stages of a homemade cnc mill/router. I heard somewhere that, during ww2, concrete was used as a substitute for cast iron due to a shortage of metals and a demand for machines. I have also seen a few plans for milling machines with concrete beds. So I am planning to cast a steel reinforced concrete bed for my gantry type mill. I plan on using 40*10 cold rolled steel for slideways and nylon blocks with backlash adjustment. Planning for travel as followws, x-2000mm, y-900mm, z-400mm. Spindle is to be driven by 650-2500 rpm bench drill press. I have extensive cnc programming experience but zero electronics. So far im planning on using a stepper motor kit available online. The motors have 200 oz-in holding torque but im not sure that will be strong enough. Most of the rest of the construction will be steel and alu angle and rectangular tubing. Will try and attach a rough design but im not sure if my cellphone browser will be able to do it. There is a lot of gusseting and cross bracing still to add to the design and the spindle has yet to be figured out but the outline is there. any feedback would be greatly appreciated.
Old 08-18-2006, 02:20 PM
A minor finger spasm resulted in a duplicate thread. please ignore this one and use the other one with the attachments.
