Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 08-13-2006, 07:49 AM
camcam is on a distinguished road
From Nothing
Two months ago I knew nothing about CNC. Then I found this Forum. Now I have a machine! I wanted to say thanks to everyone on the Forum! You made this possible!
Jgro for the JGRO plans.
Phil (PMinMO) for the 3 axis self contained board and your help for getting it hooked up and going with my Mach3.
Everyone for the ideas and pictures you shared.
Here are some pics of mine.
Jerry
Old 08-13-2006, 07:58 AM
A couple more.
Jerry
ID:	21019   Click image for larger version
Old 08-13-2006, 08:04 AM
I see a lot of people using wood or plastic to hold pipe rails. I have had good results with simple "pipe flanges". Flanges that pipe screws into. Just use a flange bigger than the pipe. They are easy to drill and tap and the threads will not strip. You can get them at any hardware store.
Jerry
Old 08-13-2006, 08:20 AM
Thanks to Phils plans I was able to make my controller. Not knowing what I was doing, I had some problems. Phil made a set of troubleshooting check points I could use on the board. Turned out his board was perfect. The problem was I had it hooked up to my IBM laptop, don't think the parallel output could switch the board. I attached it to one of my desktops and away it went. I am using Mach3.
Can't thank you enough Phil!
Here are some pics.
Jerry
ID:	21022   Click image for larger version
Old 08-13-2006, 08:36 AM
And here is the housing I made for everything.
Jerry
ID:	21024   Click image for larger version
ID:	21025   Click image for larger version
Old 08-13-2006, 08:39 AM
And mounted on the machine.
Jerry
ID:	21027   Click image for larger version
Old 08-14-2006, 01:29 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
good work ,
whats the cutting envelope?
Old 08-15-2006, 07:33 PM
Hey D,
Its about 21" X 34".
Jerry
Old 08-15-2006, 07:56 PM
I think I have the bug.
All I can think about is building Joes machine and I don't even know how to use this one.
Jerry
Old 08-15-2006, 09:25 PM
dertsap's Avatar
Gold Member
you did a nice job on your system , nice size table to play with
youll learn to use it quick enough cutting parts for joe s machine which is a good choice that is a solid looking system ,
  #11   Ban this user!
Old 08-15-2006, 10:22 PM
leberen's Avatar
leberen is on a distinguished road
I love your controller box, had you used loctite for the screws holding the pipe rails? It must run smooth!
Old 08-15-2006, 10:33 PM
spalm's Avatar
Gold Member
spalm is on a distinguished road
Wow, good job! Lots of detail taken care of. How does it perform?
Steve
