| CNC Wood Router Project Log Post your CNC machine building log here only. |
What you think about this. I call it the easy slide, because it is easy to make and fully adjustable to no play. It is hard to turn the rod arround. I'm not natural english speaker so I'm sorry if you do not anderstand. ![]() ![]() |
| Can you show a photo of how the four bearings that are embedded in the mdf are mounted ? They appear to be dropped into slots cut for clearance, but how are they held in position ? Many thanks for showing your photos. John
__________________ It's like doing jigsaw puzzles in the dark. Enjoy today's problems, for tomorrow's may be worse. |
This is my first slide design. I hope soon I'll have final dwg dravings. Bearing is spaced with common washers. The ax is tube fi. 8x1,5 mm in a slot. The ax will be the same on all bearings because the thread rod is not enought accurate. The groove is for adjusting the play. I'll use a bolt M6 to push the ax upwards, bolt will be in a furniture fitting with M6 thread. |
