Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 06-05-2006, 08:03 PM
bradyfb is on a distinguished road
Question NEED HELP (NEED FORMULAS SPI &SPS)
my motor rpm is 3200, 200 count quadutre encoder which yeilds 800 counts, i have allso reduced with pulleys 1 to 4 ratio; im useing .5 pitch ball screws (two turns per inch) need formula to figure steps per inch and what my max vel (steps per second) is
Old 06-05-2006, 08:09 PM
ger21's Avatar
800 x 4 x 2 = 6400 steps/ inch. Max velocity is how fast the machine can move reliably without the drives faulting. Use trial and error method.
Old 06-05-2006, 08:27 PM
Thanks gerry, I thought i was doing something wrong cause I get this window that says my max vel do not match XYZ,
