Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 05-26-2006, 02:45 PM
WJHildreth is on a distinguished road
Exclamation Hot Motors
Hello all,
I am nearing completion of my JGRO router. I have all three axis running with TurboCNC and only to mount the router.
In the mean time though, I have been trying to tech myself to write G Code. The file I wrote is to cut the cross slide ways pattern out for the Gingery lathe. After about 15 minutes of run time, I aborted the program happy that it was moving where I told it, afterwards I felt the motors with my hands. They were pretty hot, not enough to burn you but hot none the less.
I am running 111 oz-in motors from some Genicom printers I scrapped. They are 200 steps per revolution and I am running them half step.
Any feedback would be greatly appreciated.
Regards,
Joe Hildreth
Old 05-26-2006, 03:22 PM
randyf1965 is on a distinguished road
I have been told the motors I have are rated at 110C (DANG HOT!) but I am building mounts to put small blower under them to direct airflow over them (bfb1012h or bfc1212a) . Either one move a massive amount of air even when restricted thru a filter
Old 05-26-2006, 04:42 PM
ger21's Avatar
even if they are hot enough to burn you, they're probably rated much higher. At least 70C, usually up to 100C
Old 05-26-2006, 04:46 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I had been told 200°f is what most are rated at, so you shuld not have to worry, and like ger21 mentioned in another thread, you can run them 15-20 x the rated voltage, so lets say you have a 3v motor running at 33vdc then that is only 11x the rated v.
Old 05-28-2006, 03:59 PM
I have made a 30 and 45 minute run with them. They don't seem to be getting any hotter and the performance is fine. Thanks for all the help everyone.
Joe
