Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 11-05-2003, 07:03 PM
jgro's Avatar
Gold Member
jgro is on a distinguished road
Add another one to the list
Hi all,
I've been lurking here for a couple of months now and I've finally got my CNC router to a point where I can show it to you guys. Here are the specs:
15" x 30" cutting area
6" z travel
3 116 oz. Pacific Scientific stepper motors
1/4-20 lead screw
Skate bearings on gas pipe for guides
This power supply
I plan on using a Xylotex driver board and TurboCNC to run it.
Here is the CAD model in SolidWorks:
Old 11-05-2003, 07:06 PM
jgro's Avatar
Gold Member
Here is a pic.
Old 11-05-2003, 07:14 PM
DaSigntist's Avatar
DaSigntist is on a distinguished road
Thumbs up Your Machine
Awesome, Looks Great Jgro!
Keepus informed with pictures and details.
Regards,
DaSigntist
Old 11-05-2003, 08:36 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Thumbs up
Awesome Jgro!
And thanks - I might borrow your "outa - the - box" by being in the box for the Z axis!
I was just struggling on my design and your method may be my solution!
I like how you nested the bearings inside the rails! Helps keep your x-axis size by a bit. The rest of the rig is cool too! Nice sw image too.
Gud-on-ya-mate! (pronounce that "maight")
Jim!
mental note - lurking and doing -- not blabin' I'd better get back to the garage (that's pronounces gare-ig) and get some work done!
Old 11-05-2003, 08:44 PM
balsaman's Avatar
balsaman is on a distinguished road
Everytime is see someone post a 3D model of a machine my heart sinks a little because it seems that that's as far as it goes. The threads die without a real machine turning up that looks like the model!
I was very happy to see a real machine as I scrolled down a little farther! Very nice job. The cad part is the easy part. Putting the tools to work and building something is the hard part. Looks like you are on the right track! Looks great. Just wait till you get it going on it's own steam!
keep up the good work.
Eric
I wish it wouldn't crash.
Old 11-05-2003, 09:01 PM
bb99 is on a distinguished road
Nice Job!
I've started to design my first CNC machine and seeing your work inspires me! I have a few questions for you. First, what CAD package are you using? Also, I noticed the L-bracket under the Y-axis, what is it for and how does it work? And finally… In the CAD rendering I see that on the Z-axis, you have the topmost bearing on the front of the pipe. But, would it not be better to have it behind (since the weight of the router will "pull" the top of the carriage forward)?
bb99
There are 10 types of people in this world; those that understand binary and those that don't.
Old 11-05-2003, 09:51 PM
ezland00 is on a distinguished road
wow, great job
Where can i get a copy of SolidWorks?
Old 11-05-2003, 10:01 PM
balsaman's Avatar
bp99, I think he has 4 bearings there. at the top he has one in front and one in back. You just can't see the back bearing.
Eric
Old 11-06-2003, 12:49 AM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
My take on the "L" bracket it added support the Y rails. Chuck Knight used a 2X2 with the corner beveled for a better contact to the rail for the same reason.
Good job Jgro.
For me the cad part was too much so I went to full size plans on a roll of brown construction paper from where else, Home Depot
Hager
Old 11-06-2003, 06:21 AM
anoah is on a distinguished road
Nice Job
Nice job! Looks like a really nice design.
I have sent you a PM.
Old 11-06-2003, 07:53 AM
jgro's Avatar
Gold Member
Thanks for all the kind words. I'm lucky in that I work for a design/engineering firm and have access to all kinds of CAD software. We mostly use Pro/Engineer, but I like SolidWorks because it's a kick-butt piece of software. We also have a CNC machine in the model shop. That's where I cut alot of my parts. I did design it that it could be done on a table saw or with a router. I just wanted to learn CNC programing, so I went that route.
The l bracket is for support. I used 1/2' pipe on the x axis which is way too small. It flexes alot. I'm going to see how bad it is when it is all together and if it is untolerable, I may make a new base using larger diameter pipe or solid rod.
Here's the cad model for the Y Gantry:
jgro
Old 11-06-2003, 07:55 AM
jgro's Avatar
Gold Member
...and here's the Z gantry:
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Ferdin
Add a second set of rails to X axis..need advice. bgolash DIY-CNC Router Table Machines 5 05-31-2005 08:11 PM
DigiKey Parts List for v2.1 board ranman PicStep Controllers 0 05-27-2005 02:58 PM
How about a list of sources for Linear slides? fyffe555 DIY-CNC Router Table Machines 18 03-29-2005 01:52 AM
want to add 4th axis to stepperworld fet3 board gv71 General Electronics Discussion 5 05-29-2004 12:10 PM
