| CNC Wood Router Project Log Post your CNC machine building log here only. |
After contemplating it for a while I decided to make a start at building a router that could hold at least a full sheet of plywood. this wouild be my third router but the first metal one. I have access to 2" by 4" rectangular hollow section metal which I will use for the bearing assembly pictured, to run on. I left a space between the bottom bearings in order to support the long axis. I also have access to lots of skate bearings(608 series) from frequent copier scrapping and the 5/16" threaded rod is cheap and strong enough to tie the whole assembly together, it also fits the bearings with minimal play. It looks I should be using in the region of 64 bearings which will be no problem. The solid metal bar that makes up the corners of the runner assembly is 16mm (~5/8") square and was a pain to drill even after marking the holes with a center punch. After having the drill bit wander too many times I went looking for Black & Decker's bullet point drill bits or DeWalt's pilot point bits. These bits have a tip somewhat like a brad point bit for wood but the pilot or bullet point bit will drill metal, wood or plastic. I will get some hollow section this week to give a visual idea of how the setup will work. It appears that gear track will be the mode of motion for the long axis which then raises the question of whether the long axis will be driven from both sides, one side or the middle. My CAD skills are ok but I should make up for that with lots of pics. Jason |
| John, I found it better to place a couple of washers between the double bearing when I trialed it. There is a bit of play between the threaded rod and bearing and one beariing always lifted higher than the other. It is only slight but if you hold the bearings and spin the threaded rod you can feel it. The washers between the bearings spaced the bearings slightly apart and helped. Hold the bearings against a flat surface as you tighten the threaded rod and you should get a better result.
__________________ cheers, Rod Perth, Western Australia |
| The problem with tying the bottom together is that there would be no way to support the long axis. The top of the bearing assembly would be fastened to the assembly on the opposite side so there should be no problem. Jason |
Have you thought about belt drive for both sides for the X Axis? |
#11
| After giving belts an examination it seems that they may be the best option for me. Belts can be rolled up and easily transported eg suitcase, that would be a bit harder with gear track. I have family due for a visit to the island soon, so I will probably have them bring the belts for me. I like Benny's design as well as a design from Europe, I will probably rig up a hybrid of the two machines. My only concern is the belt stretching. Is there a special type of belt for this application? Jason |
#12
| After thinking about this, belts do seem like the easiest and cheapest way to go. 10 feet rules out screws. Have not priced gear track, but seems expensive and hard to gear down and align. With a 5 foot wide gantry, I would think you need to drive from both sides. Use an axle at both ends, with split belts tied to the gantry. You would only need one motor that way, driving the axle in the middle, under the table. Seems like everyone goes to SDP/SI for belts and gears. http://www.sdp-si.com/ Dang, this seems like a fun project, especially if you are getting some of the components for “free”. Steve |
