Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 04-24-2006, 02:38 PM
WJHildreth is on a distinguished road
Talking OK, I have finally taken the plunge
Hello all,
I have been lurking and asking questions and researching for a while now. Well, I finally got the nerve to start building my own router. I have decided to go with a stock JGRO design with the exception of using 3/8-16 allthread for the leadscrews. I am not sure how to post pictures here but am documenting it on my website if you want to look.
You can find it here:
Joe Hildreth's - My Heap Website
At this point I have the motors and controller (HobbyCNC 4 axis) and power supply done. I have the Z Axis finished and have started on the X axis.
I want to thank you all for the vast amount of very helpful information you guys and gals have provided!
Joe Hildreth
Old 04-24-2006, 02:45 PM
ShayArnett is on a distinguished road
Lookin good. I'm just barely ahead of you on the mechanicals, and slightly behind on the electronics.
Looks like yours is going together much more accurately than mine is I kinda went overboard on that "First Cut Fever" mines more like "First Machine Fever" LOL
Old 04-24-2006, 03:10 PM
Well, that is why I started from the inside (z axis) so to speak and am working my way out. I figure it is going WAY too good and I will probably notice a little to late that I have something off and will have to compensate.
Thanks for looking!
Joe H.
Old 04-24-2006, 05:12 PM
CanSir's Avatar
CanSir is on a distinguished road
I just ordered the electronics (hobbycnc 4-axis kit) and some bearings so you guys are waaay ahead of me! I'm not following plans - instead I'm stealing ideas from all over these forums. If that doesn't work, then I'll follow some plans!
Cheers!
Old 04-24-2006, 08:01 PM
I thought long and hard about doing that, but everytime I sat down and started drawing a machine from the "stolen" ideas it ended up looking just like a jgro anyway LOL
Old 04-24-2006, 09:06 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
good luck with build looks good so far. the hobbycnc kit should work good for you.
Joe
Old 04-24-2006, 09:07 PM
brady is on a distinguished road
Your plunge seems to have paid off, the project looks very good.
HOW DID YOU FIGURE OUT THE ELECTRONICS SO EASILY??
I couldn't take the extra hours to research, so I bought a 4 x 8 kit someone else started off ebay. I have picked it up and it is in parts in my shop.
Looking at your project it appears your investment in research paid off.
I will check back to see how you advance in the next while.
Thanks for the inspiration, and maybe now I will research some more.
Brad y
Old 04-24-2006, 09:17 PM
CanSir:
It was a slow start for me but once I got started it kinda gets into your blood or something. I don't have much time to work on it, but try to find 30 - 60 minutes a few nights a week to work on it. You may think we are ahead of you now, but just wait till you get into the project. You may pass us up!
ShayArnett:
I commend you. I thought about designing a machine and chickened out. I finally decided if I was going to do this thing, I just needed to get started. JGRO plans were a good starting point for me. They were easy to understand and the construction method seemed easy enough for my limited wood working abilities. :-)
joe2000che:
Thanks for the vote of confidence. It was your builds that finally put me over the edge to think I could start it. Another person that was a Huge inspiration was Bob from Bob's Metal Casting.
brady:
Well, to be truthful I have had electronic training in the Military and in college when I decided to grow up and become a computer guy.
As far as research goes, well I was so intimidated by this project, I felt like I had to know a little something before I started. But the research has just begun. I have _never_ done any CAD, CAM or G Code before so I still have that obstacle to over come.
Thanks guys for all your support!
Joe H.
Old 04-24-2006, 09:44 PM
thunterman is on a distinguished road
I was a little surprised to see my name and web site linked from yours! Glad that I could provide some useful information for your project. Really, you have to thank jgro (John) as he is the inspiration for this design.
You seemed to have gotten off to a fast start. Took me almost a half a year to get to the point where you’re at. Impressive!
I'm still changing my jgro, trying to improve the accuracy. I have cut new bearing blocks again as my originals were causing too much leadscrew whip. I'll add some pictures to my web site soon for this new design. My jgro will be used to cut out Joe2000che's latest design. I'll be making his latest creation a little smaller than as his original as the jrgo is a little too small to cut his parts out. I'll start a thread on my web site sometime this summer for this. I’m in the process of converting his design in BobCad now.
What kind of speed do you expect for your rapids? I'm using 118oz/in motors, so I'll only can get about 30-40ipm without losing steps. It's underpowered. I have purchased Mach3 software to control the machine. This software will run smoother than Turbocnc. Turbocnc is OK, but does not run as fast on arc cuttings. That issue can really increase your cutting time.
The Hobbycnc is a great little kit. Works like a charm!
I noticed that you used MDF for your adjusting blocks. Be careful with these as the tapped holes will probably tear lose when adjusting the screws. I would suggest using some plastic for these as I did for mine.
Good luck with your build and I look forward to seeing the finished product...
Thunterman
Old 04-24-2006, 09:58 PM
joecnc2006's Avatar
www.joescnc.com
Originally Posted by thunterman
Thunterman
Looking forward to seeing your build, you guys let me know if you need anything, files also.
Joe
Old 04-24-2006, 11:26 PM
spalm's Avatar
Gold Member
spalm is on a distinguished road
Wow, Genicom motors. Small world. I have worked for Genicom, now TallyGenicom (read globalization) for over 20 years. I design laser controllers, but have a few contacts with the stepper guys if you need some help. Looks like you are doing all right by your self.
Steve
  #12   Ban this user!
Old 04-25-2006, 10:56 AM
Thunterman:
Maybe I am a little strange, but giving credit where it is due is important to me, especially if my name is attached to it. I leached your image if I remember correctly. I am pretty sure I sent you an email asking if it was OK, if not PM me and I will make it right.
I think you are right about the MDF adjusting blocks. I still need to find plastic for the antilash nuts. Maybe Joe2000che can help me there. Thanks for the support! If it were not for folks like you I may have never gathered the courage to get it all started.
joe2000che:
I would be intersted in some plastic parts depending on the cost. You can email me if you like with details if you still do that sort of thing. Or maybe share the G-Code to cut them out when I get there. That would actually be better in a way for me, It would help me get past that learning curve.
Spalm:
I would really like to get my hands on the specs for the PJT80A2 motors that I have. I am assuming they are similar to the PJ80A1 that I have the specs for. (Got them here.) I made that assumption because they are the same size and both motors are rated at 1.68 Ohm / Phase. Any help or direction would be wonderful!
Thanks All,
I really appreciate the kind comments and the support you have extended to me!
Joe H.
