Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 01-27-2006, 12:06 PM
Gold Member
planescott is on a distinguished road
My Router (24x60 cut area)
Hi, Finally started on my router a couple of weeks ago. Here are some pictures. I have to say I am alot farther than the drawings I started with but still alot more to do.
Scott
[IMG] IM000801.JPG[/IMG] [IMG] IM000806.JPG[/IMG] [IMG]IM000802.JPG [/IMG]
ID:	14222   Click image for larger version
ID:	14223   Click image for larger version
Old 01-27-2006, 12:26 PM
WilliamD is on a distinguished road
Looks pretty nice! That should be a fairly ridgid bed setup. What kind of rails are you using? They look like the pillow block kind, but can't tell. Getting that much done in a couple weeks must be a good feeling. I'm almost more jealous of how much shop space it looks like you have though!
Old 01-27-2006, 01:21 PM
Gold Member
Thank you, All the rails are THK
Old 01-27-2006, 06:56 PM
whirlybomber is on a distinguished road
wow, that looks nice!
just for my info, is the 24x60 the footprint of the router, or the cut area?
Old 01-27-2006, 08:59 PM
Gold Member
Thanks whirlybomber, The table itself is 38"x72". It will cut approx. 24"x60".
Just can't wait to get it finished.
Old 01-28-2006, 06:46 AM
Jason Marsha is on a distinguished road
That's great work planescott and don't forget to keep the pics coming.
Jason
Old 01-29-2006, 01:55 AM
Gold Member
Here are some pics of my rack & pinion design. I am planning on using the GT2 5mm ( 9mm belt width) series unless anybody has a better suggestion.
Would like to here from people who have used these. [IMG] IM000807.JPG[/IMG] [IMG] IM000809.JPG[/IMG]
ID:	14278   Click image for larger version
Old 02-05-2006, 06:04 AM
Gold Member
I have been working on my router for the past week and making good progress. I decided to go with the 15mm wide belts from sdp/si (very nice stuff, highly recommended) maybe overkill but thats ok. Here are some pics of my progress.[IMG]IM000810.JPG[/IMG] [IMG]IM000811.JPG[/IMG] [IMG] IM000812.JPG [/IMG] [IMG]IM000816.JPG[/IMG]
ID:	14498   Click image for larger version
ID:	14499   Click image for larger version
ID:	14500   Click image for larger version
Old 02-05-2006, 01:26 PM
faithblinded is on a distinguished road
Really Nice Work!!!
I'm just a lurker, but from what I've seen here, overbuilding the drive system usually ends up just giving better feed rates with less whipping. And besides, with all that aluminum, the gears look just chunky enough for the machine.
Perhaps a bit sadistic, but for some reason it occured to me that your router would make an excellent modern day technological torture device. Imagine being strapped to the table with the router screaming at you to take 1/16" off your nose. YIKES!!
HaHa nice work! Can't wait to see it finished!
Old 02-05-2006, 03:07 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Very nice work! I mean VERY NICE! Have a quick question - where did you source the gears I see on the Z axis? Whats their OD and teeth count? I'm looking for some and have been all over the web and can't find what I'm looking for. Thanks in advance.
Jim
BTW - I'll add - those look like about the size I'm after - looking for 4 inch OD and a bore of 1 inch. Metal/acetal etc. SDP/SI seems to run lots smaller than what I was looking for - thanks
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 02-05-2006, 04:27 PM
Gold Member
Hi Jim, The gears are from SDP/SI. They are 70t (4.341od) and 28t(1.875od) alum. 1/2"Bore GT2 series. Two layers which gives me a total of 5:1 reduction for my rack and pinion on my y axis. I built one for the x axis also. I do highly recommend their product the belts fit very well and can't see where their would be any backlash. I have a 5tpi ballscrew for my z axis. I will have some more pics in a couple of days with the rack mounted and the spur gear(MCMASTER CARR 12pitch rack), also very nice product). I am building the machine to be a real workhorse, hopefully it will be. Thanks for giving my machine the "VERY NICE" compliment it really keeps me going.[IMG] IM000809.JPG[/IMG] [IMG]IM000815.JPG[/IMG]
ID:	14507   Click image for larger version
Old 02-07-2006, 06:01 PM
Gold Member
Well I got the rack mounted and finished up a few other odds and ends. Also ordered BOBCAD/CAM v20 and the BOBART. Can't wait to get it. Here are a couple of pics they are not that great I took them with my phone.
[IMG] rack1.jpg[/IMG] [IMG] rack2.jpg[/IMG]
ID:	14554   Click image for larger version
