Was feeling good about the progress I was making. Finished cutting all the ribs for the y axis, was going to move onto the skins for the torsion box when I noticed a problem while reading another build log. The vertical braces were not cut all the way though on others builds only pocketed. And what do many of us do when we make a mistake. Yup make more mistakes. I tried recutting the braces but did not take my time and did not align the sheet well and made a terrible cut. Ug.
So I've decided to move on and just keep building with what I have. If there is too much defelctioon I'll cut out some 1/4" mdf to glue over the holes I made. If that doesn't work I'll just cut a new y axis with the new build. Even with the cutouts this build should be more ridgid that my current setup and with the larger cutting area new parts should be a walk in the park. Famous last words.
If you don't think this is adequate let me know and I suck it up and recut the part taking my time for alignment.
LinkBack URL
About LinkBacks
