aaaaagh!
I just got the gantry rails assembled and it looks like I got the measurements out by 1/16" on the width, the gantry doesn't seem to run true on the rails (I haven't taken the rails back off to check they aren't warped but rotating them doesn't seem to help which leads me to suspect the frame or the bearing blocks are totally square.
Unfortunately my over confidence led me to believe I would do everything right first time so I glued up the dowels that hold the gantry together so it will be very hard to separate them to correct whichever piece I didn't cut correctly. I suspect it will be easier and faster to remake the gantry again......
FYI I also found that the confirmat type screws seem to do a much better job of supplying clamping pressure to the mounting holes in mdf. I realize that I don't have the same capability for using a lock nut to set the position but the holding power seems so much better that I may stick with them until I can machine myself some inserted delrin blocks for the mk II table that alread looks inevitable...
