Mach3 can not use parallel ports on a 64 bit OS.
For cutting metals with a design like that, imo, your only chance is to reduce the gantry height from 12" to about 2". It just doesn't look anywhere near rigid enough for what you want to do.
Here's a link to the only router type machine I know of on here that's used almost exclusively for cutting aluminum.
http://www.cnczone.com/forums/diy-cn..._finished.html
LinkBack URL
About LinkBacks
