got some parts cut and more cad for the next set of parts done today. pics coming soon.
this is a new design I have been working on for some time. it uses a lot of components that can be obtained at just about any hardware store. But there are a couple of components that are custom, tying the whole design together, giving it a lot of both stability, while still being very adjustable for both accuracy and longevity (in theory). Of course once I have it built I can put those both to the real world test.
ok now for some pictures.
(these next few pics are of a design with some frills to make the parts look more interesting.)
(with my makeshift vacuum shoe. learning a lot of important stuff about what makes them work really well and what happens to be some very nasty mistakes)
I love the 'steam-punk' look of the bracket in the final frame. What is the finish? Do you have to seal the hardboard?
not sure if I had to or not but the MDF is sealed with a coat of Thompson's water seal. then I sprayed it (to answer your question about the type of textured paint I used) hammered gold. plan was to go in with some sort of stuff to antique it like rub and buff.
not sure if I should have used two coats or more of the thompson's or not. just did not want to change the surface of the indention for the drill rod. might not interfere as much as I thought though and the paint might go on a bit better for sure. the hammered effect was not as pronounced as I would have liked as I have used it on something else before and it was a very steep divot-ed effect then. might be a different brand though or the fact that it was over a painted plastic and fiberglass resin (repair job on a cheap scooter body. kinda wish I had pics of it now.) anyway, that is my story and I am sticking to it![]()
also quite by accident. (still looking into what caused it) I found that I can run a 1/8th carbide end mill about 0.1" or more per pass in MDF.
I really did not know this.
I am guessing this will cut down on the wear at the tip of the endmill for sure. not to mention it will speed up how fast I can run through this material to make these parts.
I guess I should have done a bit or research to find out just how far I can and should push these bits. Would also be good to have a tachometer for my rotozip since it does not have one. To keep from burning up bits I am running mine off of a dimmer switch with the setting about half way to the cut off point for my rotozip tool. So it is not running at it's max speed so I have no idea how many RPMs I am running it at.
to anyone else running a similar tool on house hold power note from my mistakes
*to make sure that a brown out, or dip in power, when the house's central air and heat kick on, causes the tool to shut off completely. had that happen once. only once. the mill kept running but thankfully I was running the cuts so shallow that it did not make much difference. if it had been cutting deeper ofcourse it would have snapped the bit. *
Congrats on the machine! It seems to cut very well for such a simple construction.
Re the tachometer, if you get a SuperPID speed controller to control your Rotozip it has an accurate digital tachometer AND will provide good speed control and good power at low speeds. This should be considered a shameless product plug as I designed the SuperPID and receive some money from it's sales.![]()
cool you have a link to the SuperPID? I definitely need something to keep track of that, so I can calculate depth and speed for my mill and bits on various materials for sure. I know MDF is a bit of a mixed media, as being mostly wood it still throws occasional sparks from my band saw when I am cutting it down to load it on my mill.
actually I have another question about the SuperPID. it says it can be controlled by mach3 but I am wondering if it can be controlled by say turboCNC? this is what I use mainly being that it works well for me. I would like to have access to control like this on it, but not seeing anywhere that it can be done. I am running a stepperworld board (FET-4) and it has inputs, so I am wondering if the SuperPID can send a speed signal to that for turbocnc to know what the RPMs are? just wondering. would be cool if it can do those things. otherwise I would probably just get a manual ran unit to know what my RPMs are for calculating my feeds and speeds.
I guess I should note too that I found the siteand I am definitely getting one just want certain information before I make my selection is all
here are those pics I kept promising. sorry I have been negligent on my updates
The sales site is;
www.SuperPID.com
This forum has a popular thread with lots of SuperPID users and tech support;
http://www.cnczone.com/forums/diy-cn...ontroller.html
Ok, re TurboCNC, sorry I'm not sure what features it supports. If it has a feature for an output pin, to turn the router on/off, then it can be used to control the SuperPID to turn the router on/off.
The other feature is to control the router speed. Many people (like myself) just use the manual knob that comes with the SuperPID for that. Generally you use the same RPM speed for the whole cutting job anyway.
If you want TurboCNC to control the speed, then TurboCNC needs to have the feature where it sends out a PWM signal to control spindle speed. This is often called a "VFD" control signal or "VFD voltage".
Re the stepperworld board, if it has inputs that send a signal back to the PC then the SuperPID has a "TACH" output that sends the tacho signal back to the PC. Then if your PC software has the feature to display that tacho signal then you cvan display RPM on the PC. Note that RPM is already displayed on the Super-PID display.
I have to ask, what are the cool looking little bracket things for?
sounds good, I will definitely look into each of those.
The bracket thing (if you are talking about, what I think you are,) are rail supports to keep the drill rods from expanding when the bed carriage is rolling back and forth on it. the head of my mill you see there, has only really one problem stability wise and that is the flex it has from side to side. so these would eliminate that.
