Page 4 of 6 FirstFirst 123456 LastLast
Results 37 to 48 of 66
Thread: ER16 Router Spindle Build
  1. #37
    Jan 2005
    Khalid
    The video of this one will be up to the customer
    The spindle Taper when finished will have Zero run-out
    When it is complete, The taper will be reground with the spindle completely assembled
    It then depends on how good the collets & tooling you use, This will determine how much run-out you will have
    Mactec54
  2. #38
    Jan 2005
    To assemble the Spindle & lock the End Caps in Place, A Pin Wrench was made, to torque the the front & rear End Caps
    The front End Cap holds the outer race of the Bearings tight into the Bearing pocket,This is part of the preloading of the Bearings
    The rear End Cap has a Smalley Wave Spring in front of it, for thermal expansion of the Spindle
    Spindle Mounts also in place
    Attached Thumbnails Attached Thumbnails ER16 Router Spindle Build-spindle_pin_wrench-11-1.jpg   ER16 Router Spindle Build-spindle_pin_wrench-11-2.jpg   ER16 Router Spindle Build-spindle_pin_wrench-11-3.jpg
    Mactec54
  3. #39
    Registered Drools's Avatar
    Feb 2009
    Fantastic, one more question, how many hours have you put into this project? I'm thinking it is just about done now.
    Thank You.
  4. #40
    Jan 2005
    Drools
    Yes it is all finished except for grinding the taper, & that will get done when I have finished doing a production run for another customer
    Mactec54
  • #41
    Jan 2005
    The last parts for this build, are the pulley,pulley retainer & spindle mounting base plate
    This plate was made for the the machine that this spindle will be fitted to
    Attached Thumbnails Attached Thumbnails ER16 Router Spindle Build-spindle_pulley-12-1.jpg   ER16 Router Spindle Build-spindle_pulley-12-2.jpg   ER16 Router Spindle Build-spindle_mounts-9-1.jpg   ER16 Router Spindle Build-spindle_mounts-9-2.jpg
    ER16 Router Spindle Build-spindle_mounts-9-3.jpg   ER16 Router Spindle Build-spindle_mounting_plate-9-4.jpg   ER16 Router Spindle Build-spindle_completely_assembled-14-1.jpg
    Mactec54
  • #42
    Apr 2009
    Thumbs up
    That looks amazing!!
    Cant wait to see it perform
  • #43
    Oct 2005
    Mactec54- I'm still interesting in buying one to go on my new CNC machine.
    If you like, please PM me with some ideas on price and time. I would like a stripped down version, just spindle and collet nut etc but no pulley or mounts. I'll make mounts to suit my machine and might use a toothed pulley to a DC motor, I have some stuff here already for that. Thanks!
  • #44
    Feb 2006
    Just trying to show what can be done to build a simple spindle, That DIY guys could do & use
    I'm just a hobby machinist, but would like to try something like this for my CNC router. What special tooling/machining was required to be able to machine the collet holder? I'm guessing it was hardened steel? I've never done anything harder than mild steel on my mill drill or lathe. (I did drill some stainless steel once, and I just put a dent in it and turned it bright orange!)
    I'd also love to see your set up for regrinding the collet on the finished spindle. I bought a cheap chinese spindle (not through ebay - stupid!) which has terrible runout. I'd like to try and correct it before scrapping it.
  • #45
    Jul 2007
    I really like the mounting brackets you made. They look so clean. How did you cut the clamping slot? Was that done by hand?
    bob
  • #46
    Jan 2005
    rowbare
    The slot was done mostly on the mill, The hole was drilled at the end, then cut with a .050 slitting cutter, from each side, it then just has a small piece in the middle to do by hand
    Mactec54
  • #47
    Tinkerer
    Nov 2009
    It is so fun to see beautiful craftsmanship! Especially after having the tools but lacking the knowledge. I can now appreciate the planning, execution and effort required to accomplish some of these things. Bravo and thank you so much for sharing.
  • #48
    Registered JohnnyVegas's Avatar
    Jun 2009
    Will you ever attempt a draw bar on another spindle? That would be interesting.
    www.digitalPimple.com
  • Page 4 of 6 FirstFirst 123456 LastLast
    1. Does anyone have Taig Spindle ER16 Dimensions or 3D model?
      By jupdyke in forum Taig Mills & Lathes
      Last Post: 04-20-2011, 02:37 AM
    2. Spindle Motor for Taig ER16 Spindle
      Last Post: 04-15-2011, 12:33 PM
    3. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    4. Newbie- Spindle and ER16 tooling
      By sujeet_nayak in forum CNC Tooling
      Last Post: 04-11-2010, 11:23 AM
