Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #13   Ban this user!
Old 10-04-2005, 04:00 PM
maxvovk is on a distinguished road
Originally Posted by ViperTX
Nice, but how does the x-axis move....there seems to be something missing in your drawing....I see the y-axis and z-axis....I suspect that you are moving the frame that holds the y and z axis....something is missing...
There is no rail X. On the other hand bearing will be big and thick ballscrew. Simply I draw drawings on a place when I do details. And with X I yet do not know - there is a desire to lift a rail upward - that it was possible to put a wide leaf of a material on all length X... But then rigidity will decrease... It is necessary to apply thick metal pipes and corners... Here I also think - on what to stop.
http://mycnc.ru
Old 10-04-2005, 10:22 PM
Gold Member
Mariss Freimanis is on a distinguished road
OK.....Can't design your own drive?
Mariss Freimanis
Quote:
Drivers - analogue Gecko, its full copy, PCB are made by means of PCAD-2001, a photo mask printed on the jet printer, Positive resist and chloric iron.
Old 10-04-2005, 11:03 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Hmm, yes I missed that one. I guess the horse has already bolted and you have already made them. I do suggest you edit your post in reference to your copied drives and possibly the list of software you use.
Wow you have an impressive amount of software.
  #16   Ban this user!
Old 10-19-2007, 03:03 PM
rmsimoes is on a distinguished road
I have tested also, and motor sounds a bit better than using a3977 ic. but it really needs a good heatsink
  #17   Ban this user!
Old 10-21-2007, 02:28 AM
harryn is on a distinguished road
Hi, if you are looking for a proven out stepper driver design that is all set up for open source / anyone can build it, you might want to look here.
http://www.cnczone.com/forums/showthread.php?t=9564
It is not a Gecko, but then again, your project might not need them yet. The parts needed are pretty universally available, and the kit version is cheap.
  #18   Ban this user!
Old 10-21-2007, 05:59 PM
you are right. I have seen it also at www.damencnc.com
but I bought all stuff to work with bipolar. connectors and even shielded cable from Igus.
the kit assembled seems to be affordable and I really prefer mosfets instead of an expensive IC.
I am planning another project with servos at x and y axis and stepper for Z.
for the price and simplicity it may be a solution for me. now I am testing TA8435 and then I'll take a few more conclusions.
