Results 1 to 3 of 3
Thread: Measured rigidity of home-built machines
    Aug 2011
    Since I am not satisfied with the rigidity/accuracy of my current CNC (an off-the-shelf Shark Pro Plus) I started building my own machine (see this thread). That Shark has a ridiculous flex of 1.5 to 5/1000" per pound load in x and z direction depending on the position making it hard to use for anything other than light woodworking (or VERY slow aluminum machining)
    I tried to design the new machine very solid and I am confident I can do much better but I am curious if there was ever a comparison of actual measured rigidity of home-built machines depending on the concept (materials, size etc.). While rigidity is mentioned very often I have not seen any objective numbers.
    So my question is if there is any information hidden in this vast forum.
    Thanks, JB
    Registered jsheerin's Avatar
    Aug 2008
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Aug 2011
    Thanks a lot! That is what I was looking for.
    JB
  1. 3 Custom machines built in 2 minutes
    By Mountain States in forum Videos
    Last Post: 05-04-2010, 10:14 PM
  2. Home built barfeeder
    By Fudd in forum General Metal Working Machines
    Last Post: 01-28-2008, 09:50 AM
  3. home built cnc router
    By sanjiv in forum DIY CNC Router Table Machines
    Last Post: 08-17-2006, 04:43 AM
  4. Home built cnc lathe
    By roni21702 in forum Stepper Motors and Drives
    Last Post: 02-11-2006, 04:53 PM
  5. Another home built router :)
    By steveald in forum DIY CNC Router Table Machines
    Last Post: 03-19-2005, 01:22 PM
