| CNC Wood Router Project Log Post your CNC machine building log here only. |
| LinkBack | Thread Tools | Search this Thread | Display Modes |
#229
#230
![]() Cheers Bruce |
#231
Lou
__________________ http://www.cnczone.com/forums/diy-cnc_router_table_machines/140832-new_fla-100_kit_build.html |
#232
| See the 5th pic in post #70. There are two small " wings" at the bottom, and the nuts are mounted to those using a small piece of aluminum angle. The threaded rods go through the "wings". Thanks, Lou.
#233
| Nice looking build ger21. Plenty of style points. Looks like a factory build.
__________________ My CNC build: http://www.cnczone.com/forums/genera...ml#post1059321 C-Constant N-Nonworking C-Contraption |
#234
| I thought I'd post some pics of something I'm working on, because it's coming out pretty cool. I built a vacuum veneer frame press, and I'm working on the vacuum pump. It's a highly modified Joewoodworker venturi. 2 Venturi's, 2 MAC valves, 2 4" PVC reservoirs. All quick connect hose fittings. Joewoodworker was out of Venturis, and while browsing Ebay to try and save some money, I had a change of plans and spent twice as much. ![]() Eventually, the base for the table will have cabinets, and I wanted to do rippled water drawer fronts. So I figured I'd make an end panel as a test, and mount the pump to the end panel. The panel is 3/4" MDF, sealed with epoxy after a "rough" finishing pass, followed by the finish pass. No sanding was done to this MDF panel. I brushed on a coat of silver hammered paint as a sealer, waited 45 minutes, then sprayed blue hammered paint. 45 minutes more, and one more coat of blue. If you don't recoat the Rustoleum hammered within an hour, you're supposed to wait 48 hours before painting again. The blue paint really made it look good. The panel is 20"x30", and the finish pass tool 4 hours. I used a 1/4" core box bit at 190ipm, and used the Tempest trajectory planner for Mach3, which runs my machine a LOT smoother, but a little slower. I'm hoping to have it all assembled in a day or two, if I have everything I need.
#235
| Nice work! Looks like a piece of molded ceramic. No sanding....that's the ticket.
#239
| The panel was done in Lightwave, an animation program. I start with a highly subdivided box, and apply procedural texture deformations to it. The nice thing about this method is that I get a realtime rendered preview of what the panel will look like. Lightwave isn't cheap, but you can probably do something similar using Blender, which is free. I then brought the panel into Aspire, and added the bosses to mount the brackets to. I was going to make some pockets for button head mounting screws, but changed my mind. I'm going to mount it with 3M vxb tape, which will be much cleaner.
| Techno-Isel CNC router for sale? | Noah | Commercial CNC Wood Routers | 5 | 11-27-2008 10:12 PM |
| Finding The Right Router | Crushmonkey | Commercial CNC Wood Routers | 22 | 06-19-2006 01:17 AM |
| Quick built router | CNC Darren | DIY-CNC Router Table Machines | 10 | 06-05-2005 08:09 PM |
| long term stability of wood framed router | dave925 | DIY-CNC Router Table Machines | 17 | 05-05-2005 11:33 PM |
| my new longbed router | cncspear | DIY-CNC Router Table Machines | 16 | 10-15-2004 08:36 PM |
