| CNC Wood Router Project Log Post your CNC machine building log here only. |
| Scalable / Adaptable Gantry Router My need for a mechanical solution started with the realisation that I could not cut things accurately by hand! As I initially wanted to create a set of railway carriages, it relied upon repeat accurate cuts which apart from not being able to do seemed extremely time consuming and boring. After researching the web, I discovered CNC. I have had a long time ambition to start a hobby for retirement and model engineering was my answer. I have no training or practical experience in any of the skills needed for model engineering. Building a CNC machine seemed to be a good starting point. (I'll need lots of help in the electrical bits )I realized that a CNC machine would enable the repeat accurate cuts that I needed, however I also realized that I could build a tool that satisfied the above need but that tool could also become very limited unless I designed with future projects in mind. So my imagination took over and I thought of a long list of wants that this machine could achieve. One thing that seemed obvious was that if I build a small machine, I would get frustrated by its limitations and that as soon as I finished the first I would want a second. I also argued that a small machine does not imply increased accuracy or reduced complexity, just reduced outlay. So if the choice was two machines or one machine, then one large machine made better sense even thought the initial investment is high. That left me with a whole heap of design criteria such as: size of cutting footprint, thickness of material to be cut, type of material to be cut, etc. Furthermore, I realized that these machines could wear a whole range of adaptations such as lasers, air brushes for painting, die grinders, belt sanders, orbital sanders, jigsaws, etc. Also, I could experiment with cutting glass, stone, metals, plastics, etc. I was not limited to 3 axes either and could incorporate a turntable or a swivelling head, etc. I opted for a design that would take a standard sheet of material made of hardwood or aluminium whilst keeping my options open for more challenging materials. I also felt that 6in travel for z axis was a reasonable challenge, whilst allowing for additional axes to be retro fitted. I then reasoned that a standard sheet of 2400 * 1200 seemed a lot of investment for something that was still basically a hobby. It was then that I decided upon modularisation. I decided to build a machine that would take 1200 * 800 with the ability to be converted to a 2400*1200 (that is 1200*800 + 1200*800 + 1200*800) easily. With a modularisation target in mind, I concluded that I would have to have a gantry design as then, the only significant change from 800 to 2400 was the lengthening of the x rails. With a gantry, I am able to put the x, y and z motors all on the gantry. So, I was committed to a footprint of 800 (x) * 1200 (y) with a 6inch z travel. That led me to be concerned about structural strength. I thought that a gantry supporting a router assembly spanning a cut of 1200 would require reasonable strength. Hence, I decided upon mild steel for all assembly. Apart from anything else, I wanted to learn how to work with metals including cutting, tapping, welding etc. Also, I didn't like the idea of aluminium. I didn't think it would be strong enough and I was concerned about prolonged use introducing fatigue. As a person who knows very little I might be wrong on that consideration. I also thought aluminium would prove more expensive. (Still don't know ... haven't compared!!) So, by deciding upon a machine of this size, I did not find out until much later that I had inadvertently committed myself to at least gecko level controllers and 400oz/in motors. I had a long look at steppers and they seemed to be understandable. I had a long look at servos and they still seem like an absolute minefield. Also, I had a long look at drive gear and compared threaded rod with timing belts. Timing belts seem a lot simpler for me so that is the path I have taken. Furthermore, with the possibility that my machine might be expanded on the x axis from its existing 800 to 2400, timing belt extensions are far practical to extend than threaded rod! Also, it had to be elegant. I wanted to create a machine that looks simple and is a joy to watch. That means that I had to ensure that it looks balanced, designed with simple structures of triangles, circles, lines and rectangles In summary, I realized that the design criteria I had set was for it to be elegant in design, robust, functionally effective, accurate and modular. So, I have started this log to show everyone what I have created. So far, it has consumed a heap of time (both thought and build) but when I compare with other logs, not that much money. Mild steel is cheap. I reckon the cost of the frame and gantry and head and router but excluding motors, controllers, drive gear is around $800 Australian. Three geckos ($450), 3 400oz steppers ($400), control box ($150), timing belt and gears ($200) will keep my investment to a total of around $2000 which I reckon is pretty cheap. Furthermore, changing it from a 1200*800 to 2400*1200 machine will probably only cost me an extra $800. Considering a finished model railway carriage in Gauge 1 could cost me $2000 then I reckon I'll be in front very quickly.... plus I'll have had the satisfaction of getting this machine finished and be able to use it for heaps of other projects. At this point in time, I have been working on this for about 9 months. A lot of it is in semi assembly but I have now started to go back over it all from the beginning with a view to bedding down prior to proper assembly. I have got some pictures and will soon get the first group on this thread in the next few days. I hope this log will be of help and look forward to any feedback. Andy |
| Looking forward to seeing what you've done! |
| Attached are 4 pictures of the frame of my router. The first picture shows the basic frame. I decided to have it as a low level frame to make it more portable ensuring that the rails and gantry are removable thereby allowing the basic frame to be stored when not in use. I have been concerned about transmitted vibration and have therefore contemplated putting it on a solid table or alternatively extending the legs of the basic frame. If I take the latter option, I could attach proper feet. I have yet to decide. As you see, the basic frame is merely a box with four posts on each corner. Those posts will take the X rail supports. After a while, I realized that the frame had very little torsional strength. Furthermore, angle iron can flex in its own right and is less rigid than box section profile. I decided to strengthen the basic frame by introducing triangulation onto each corner and infilling the shape with particle board which is glued into place. I have taken the bracing one stage further and have glued particle board around the outside. The basic frame now is a lot stronger, has much reduced torsional flex and is still quite light. The strenghening process was quite cheap as all it took was a bit of particle board and 8 pieces of 20*20*3mm angle iron and a few bolts. You will see in the second picture that I have placed the 'x' rail supports onto the vertical posts. You may recall that this machine is modular. All I need to do to change it from a 800*1200 to a 2400*1200 is create more rigid posts and increase the 'x' rail (and support) in length from 800 (+ 250 mm overhead) to 2400 ( + 250mm overhead) and extend the accompanying timing belt. With the basic frame and triangular strengthening, I have left sufficient room to accommodate a turntable. The working height of the machine will be achieved by placing a series of bars across the top of the frame and bolting each bar onto the top of the basic frame. Those bars will then be about 250mm below the top of the vertical posts which will alllow enough room for the gantry and router assemble and still enable 6in z axis travel. The vertical posts are 40*40*4 square section. The frame is a mixture of 50*25*2mm rectangular section and 40*40*3 angle iron. All pieces have been bolted together with enlarged holes to allow adjustment. Welding will happen (maybe!! - I'll see if I need to first). Instead of welding, I could always use epoxy glue and bolts. Andy |
| I like the modular concept but with all of the bolts and oversized holes I'm wondering if you aren't going to have problems with rigidity. |
| I'm open to more feedback on that as it is something that concerns me also. I have a number of options open to me.
Taking the incremental approach further.......... The introduced chipboard will definitely improve rigidity on a number of planes however given that I am going to put a working surface over the frame by placing multiple steel rods across (say 5 lengths of square section 30*30*3 spaced evenly) then I might find that by only welding those down it could be enough to give me the rigidity I need. I could also weld corner plates on and that might be enough. All opinions welcome. Andy Last edited by andy_ck87028; 09-26-2005 at 06:06 PM. |
| Hi Guys Exciting day for me today. I spent the day cutting and bolting my y rails. X rails are assembled as is gantry frame, gantry trucks and head assembly trucks and head assembly itself. So, I now have a head assembly that moves in two planes. The router assembly is positioned in place and now I have to put in the z rails. (4 already purchased using silver steel rods and will be placed on each corner of the router with movement achieved through bronze bushes (teflon coated)) Am aware of lots of concerns regarding my design but maybe not all ..... so feel free to comment. Happy CNCing Andy |
| Andy, Thanks for the update. I'd like to see how you are supporting the X axis rails. Do you support them just at the ends or the entire length? Please keep us updated as you make progress. It inspires others like me and gives us new ideas. Rance |
| Rance Hopefully these pictures will give you an idea. If x sags, I can always put a torsion box underneath. The beam is 40*40*4mm Regards Andy |
#10
| I like the way you tied the rod down, looks very sturdy. |
#11
| Hey Andy, I now understand what you were saying this morning with bolting the Stainless to the two plates. I don't think you'll have any issue with the angle iron flexing and causing you problems. So the pipe is only secured at each end? Cheers Michael |
#12
| Mike Thanks for your encouragement. The stainless is supported from underneath along its full length with the angle iron, square section and plate sub-assembly shown. The stainless is pulled down onto that sub-assembly repeatedly along its length(on average one stainless bolt every 200mm). Both x axis and y axis rails are constructed the same way. Any stainless tube / mild steel expansion differential will be accommodated without weakening the assembly. Welding / glueing can occur throughout the sub-assembly with the exception of where the stainless tube is bolted down onto the mild steel sub-assembly. Looking forward to you and Nigel having a looksee. Andy |
