Results 1 to 2 of 2
Thread: First Build
    Registered avidesk's Avatar
    Jul 2011
    First Build
    I'm still in the design phase of my first build, but wanted to post my design progress before I even start fab and assembly. Maybe you guys can catch any mistakes before they get beyond the 3d model stage.
    It will be a fairly small benchtop unit just because of the amount of space I have available in my little garage. A smaller unit should also help with the cost side of things I hope.
    All I have designed so far is the Z-axis. As designed it would have 3 inches of travel. I'm using a THK HRW35 rail that I got from a co-worker. At the time of writing this it is the only physical part I have. I plan on making the structure from aluminum. I work for a company that builds custom automated machinery, so I have a lot of raw materials available at pretty good prices. I will probably use 80/20 as well, though I haven't decided how much. I'm going to get a decent estimate of the cost per pound of aluminum I get from work, then try to compare that to an 80/20-centered design.
    Z Axis Assembly Drawing (PDF)
    Jul 2011
    I think I have the overall construction figured out.
    Overall Assembly Drawing (PDF)
  1. Build Log: RMGVideos XZero Raptor Build
    By sagreen in forum DIY CNC Router Table Machines
    Last Post: 05-10-2011, 04:00 PM
  2. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum General Waterjet
    Last Post: 04-08-2011, 12:16 AM
  3. Joe's 4x4 hybrid build/2006 build
    By krap101 in forum DIY CNC Router Table Machines
    Last Post: 08-09-2010, 06:30 AM
  4. New Large Table Build in Houston, TX (Build Log)
    By anitel in forum Plasma, EDM and other similar machine Project Log
    Last Post: 12-30-2008, 03:45 AM
