Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: 350x400x150mm moving gantry
    Jul 2011
    hi,
    i have been looking at making a cnc machine,
    i am a uni student studding software engineering,
    right now i have made a simple fixed gantry using printers,
    but i need more strength and precision.
    [nomedia="http://www.youtube.com/watch?v=DBIhvvAZjak"]YouTube - ‪CNC/Plotter made from Printers‬‏[/nomedia]
    these are the parts i have ordered
    SBR20-400mm(2supported rails+4 SBR20UU bearing blocks).
    SBR12-200mm(2supported rails+ 4 SBR12UU bearing blocks).
    4 items SHF20 shaft end supports
    linear bearings blocks 4 SC20UU
    3 anti-backlash ballscrew RM1605-400mm-C7+3set BK/BF12
    1 anti-backlash ballscrew RM1605-190mm-C7+1set BK/BF12
    4 couplings to suit motors with a 6.35mm shaft
    as in the video i have a arduino controller which i have been programming, with my own software on the pc to send the g code, i plan to add SD support
    i have some steppers lying around and i plan to use them,
    but if there not enough what size would you recommend,
    i plan to mostly cut wood,plastic,PCB and maybe some AL.
    i also want to make this into a 3d printer
    i am not sure what to make it out of
    i have been thinking of mdf/hpde
    i have enough tools to work with steel/wood/plastic
    for a moving gantry i have decided to go with twin x axis.
    but what should the layout be,
    i have two designs.
    Attached Thumbnails Attached Thumbnails 350x400x150mm moving gantry-desing_3d_v2.jpg   350x400x150mm moving gantry-desing_3d.jpg
    Jul 2011
    The parts have now arrived
    Apr 2011
    M&G in Fyshwick stock plastics for turning etc. Also lots of milling and lathe tools. You can get 2nd hand Al and brass etc in Collie Street at the back of the metal shop. They do recycling there and sell by the kg.
    Welcome.
    Garry
    Jul 2011
    sweet thankls
    Jul 2011
    will be interesting to see your progress. im trying to decide what to build a x2 mini mill convert to cnc or something like you are building will watch your thread closely
    Jul 2011
    i have now finished the build, it was super easy, but i have misplaced the camera, so i couldn't take pics, but when i find it i will take a vid, and some pics.
    using nema 17's for the x and 23's for the y,z the fastest i have pushed it is 1m/min
    so far the cost in USD
    $530 for the rails, ball-screws
    $160 for the controller/driver
    motors from scrapped printers,
    rotatory tool already had
    $20 for mdf,pine and screws
    other parts already had
    $710 including postage
    Total cost $655 AUD
    Jul 2011
    Photo's
    The mess
    the controller and drivers
    My DIY e chain, Drag Chian
    Attached Thumbnails Attached Thumbnails 350x400x150mm moving gantry-p7255434.jpg   350x400x150mm moving gantry-p7075424.jpg   350x400x150mm moving gantry-p7255435.jpg   350x400x150mm moving gantry-p7255436.jpg
    Jul 2011
    i have dome some work,
    i had been busy with uni,
    here is my first attempt at cutting a pcb.
    http://www.youtube.com/watch?v=KIPlmpQKWVM]first pcb mill - YouTube
    Attached Thumbnails Attached Thumbnails 350x400x150mm moving gantry-2011-09-13_15.33.02.jpg   350x400x150mm moving gantry-2011-09-13_15.33.16.jpg   350x400x150mm moving gantry-2011-09-13_15.33.39.jpg   350x400x150mm moving gantry-2011-09-13_15.36.21.jpg
    Apr 2011
    Nice work!
    Looks good to me.
    Jul 2011
    here is my second attempt, one of my x motors stalled, i forgot to turn up the current after changing psu
    Attached Thumbnails Attached Thumbnails 350x400x150mm moving gantry-2011-09-13_18.02.00.jpg
    Jul 2011
    3rd attempt at PCB
    Attached Thumbnails Attached Thumbnails 350x400x150mm moving gantry-p9200010.jpg
    Registered acondit's Avatar
    Apr 2005
    It is looking a lot better but it looks to me like I still see a couple problems. Am I seeing correctly, or is it OK?
    Alan
  • Page 1 of 2 12 LastLast
    1. Trade offs between Moving Gantry and Moving Table
      By gregmary in forum DIY CNC Router Table Machines
      Last Post: 04-22-2011, 02:48 PM
    2. Moving Table, or Moving Gantry? (For Router)
      By Cryptonic26 in forum DIY CNC Router Table Machines
      Last Post: 04-20-2011, 03:38 AM
    3. Gantry: planning to design moving open gantry
      By rdcd in forum Mechanical Calculations/Engineering Design
      Last Post: 11-14-2009, 04:52 PM
    4. Discussion of moving table vs moving gantry
      By rkremser in forum DIY CNC Router Table Machines
      Last Post: 02-20-2008, 04:59 PM
    5. Moving Table vs Moving Gantry; Dremel vs Router
      By chuckknigh in forum DIY CNC Router Table Machines
      Last Post: 03-27-2007, 09:48 PM
