| CNC Wood Router Project Log Post your CNC machine building log here only. |
| A lucky find, a good machine? I am so very happy! I happened upon some linear motion stuff for free! Some was even new in box! What I have found: -2 times 120 cm (48") IKO LWHD25 rails with 2 bearing blocks per rail. These were new in box. -4 times 110 cm (45") NSK LGY25 rails with 2 bearings each. These are mounted 5" apart on a 1/2" thick metal plate. I have two plates with two rails each. One of the bearing blocks is missing it's balls though. -1 times 94 cm (37") 20mm NSK2009z ballscrew with front and end bearing with a 150oz/in SloSyn stepper attached. -1 times 123 cm (48") 20 mm NSK2009z ballscrew with front and end bearing and a huge whopping 450oz/in stepper attached. -2 times a 55 cm (21") 15mm rail with one THK RSR15VM bearing each. I will post pictures in a few moments. I was thinking of using one of the plates of with the 2 NSK rails with the 37" ballscrew module as a complete Y-axis. The new IKO rails with the longer ballscrew will be the X-axis. I am unsure what to do with the z-axis though. It is highly unlikely that I will happen upon more good stuff any time soon, and building the Z-axis with crappy parts would be a waste of this lovely stuff. Can anyone help me sort out my design? Kind regards from a very happy Tim! |
| Hi, here are the images! I have a crappy digital camera, and I hope this is posting is not against the rules. |
| Those appear to be precision ground BS big $$$, not the cheaper rolled version. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Yes, I am very happy with my find, as you can imagine! Is there anyway to order new balls for the bearing block that has lost its balls? How much would that cost? At the moment I do not have a way to make a good Z-axis. I could, in theory mount one of the two plates with the NSK bearings on the Y-axis and have almost 30" of Z-travel. I wonder if that is a good idea though. Perhaps if I built it like the one at rainnea graphics: http://www.rainnea.com/5-Axis-Router-3.jpg The x-axis rails up high with the large z-axis dropping down. Another question I have is, will it be okay to drive only one side of the x-axis, not having the ballscrew in the middle of the moving way? I know this can cause binding problems in MDF/skatebearing/allthread machines, but is it really an issue with these high quality components? If it really is an issue I have to scrap that rainnea idea. Last edited by ger21; 10-08-2005 at 01:03 PM. |
| The only potential problem I see with this design is the long reach between the router tip and the Y axis. This could allow lots of unwanted flex. On my first machine I had a 400mm reach but was only cutting 20mm sheet. If you are cutting only sheet material ( unlike what Rainnea does) make your reach as short as possible. |
| Have you any more pics of this rainnea machine |
| Yes, more pictures are here: http://www.rainnea.com/cnc_5axis.htm I would like to do some 3d work as well, not only sheets. Would these large 25mm NSK rails flex so overly much in their bearings? And what about driving it from one side only, would that cause problems with such high quality materials? |
| You need to establish what would be the max size you will be doing, I would try to avoid long z axis travel as it is very difficult to get rigid enough to prevent flexing without spending big bucks. I would be surprised if the 25mm rails would flex much, You need to decide what are you going to build your machine out of MDF, Alum, or alum profile section. With these rails I would tend to bolt them to a length of the profile section it can be bought fairly reasonable if you look around. You can also bolt them streight onto a mdf made machine, have a look at Balsamans machine on the forumn he first built one from mdf using rails like yours then a second machine all made from profile section and aluminium. You can drive on one side no problem, you just need to have everything spot on. Need to decide what type of machine you are going to build, fixed gantry or moving gantry, you don't need to have an axis overhead like the rainnea machine it still can be moving gantry with the axis driven in the middle underneath the cutting area. |
| Right, I have decided that a metre long z-axis weighing 100 pounds isn't going to help me. I have been looking around for specs on the bearings by NSK, the used ones and came up blank. I want to know if it is allright to mount them vertically like the way balsaman did on his first router. They are most likely far better suited to forces that push it "into the rail" but I want to know if it is okay to use them upright anyway. Kind regards Tim |
#10
| Flex ...kinda depends on the material and how agressive the cut. I would think most of the NSK stuff is good for any mounting in any direction. Part Number?? |
#11
| I think it's ok to use them vertically if you make sure there's not to much weight in front of them (if you mount them with the upside of the trains facing the front). Or use something as counterweight. Btw where in Holland can you find this stuff ? Jeroen.
__________________ ____________________________________ Jeroen |
#12
Jerber: I have no idea where to get more of this stuff. I got lucky. You might want to try PCB companies. The PCB hole drillers (like Posaluxes or the like) use this kind of stuff. Perhaps they are scrapping one? I managed to revive the bearing block which lost it's balls, bought 100 new balls at a local bearing shop. And my hobbycnc driver kit has arrived. Let's hope it all works soon! Any more hints/comments about the construction of this machine? |
