Results 1 to 11 of 11
Thread: Looking for a dxf/dwg
    Registered Drools's Avatar
    Feb 2009
    of 8020 (3030) end view with CRS attached and one of the cncrouterparts.com carriages. I was going to start a new drawing but maybe some one on here has one they would share. The same in 1530 would work to.
    Thanks for the help.
    Jun 2008
    Go to 80/20® Inc. - The Industrial Erector Set� and follow link to 3D Parts Stream
    George
    Registered CNC Lurker's Avatar
    May 2009
    CNCRP has DXFs of most of his mechanical parts, I didn't know if you need the extended or regular, but they are both here:
    CNCRP Mechanical Components LINK
    http://paul-flores.com/
    Apr 2007
    America
    These are Sketchup Files [.skp] aluminum & extrusions - Google 3D Warehouse Search,
    but can be exported out of Sketchup as dxf file with use of Download DXF Export for SketchUp - AutoCAD DXF file export plug-in for SketchUp
    You might also look here for a translator [skp => dxf or dwf]
    3D Modeling Software - Free software downloads and software reviews - CNET Download.com
    Feb 2009
    Thanks everyone. I'm ok at ACAD, I can make a line and join it to another. Has anyone noticed the dxf drawings provided by CNCRP are not to scale? I was able to locate and use some ACAD drawings for the 8020 parts but I would like to be 100% sure on the CNCRP drawings which I'm not. On the CNCRP drawings there are 2 weird lines which I'm not sure what they signify. Even when I have the part scaled to where I think it should be (length = 8.5”) the distance between the bearings should be .25 or there about but I measure .2100.
    Attached is the end view I’m after, circled in red are the lines I’m not sure of. I understand one bearing moves and I can fix the drawing to where I THINK they should be but will it be 100%?
    Attached Thumbnails Attached Thumbnails Looking for a dxf/dwg-cncrp_carriage.jpg
    May 2009
    I think that squiggly line is supposed to be a split lockwasher. You're right as far as moving a bearing since it rides on a slot. That drawing also shows button head cap screws, but actually hex bolts are used.
    Attached is a partial view to help you out. I didn't include the whole thing because I changed the lengths of some of the extrusions and it would throw you off if you copied mine exactly. (I didn't bother modeling the lockwasher and bolt on the carriages)
    Attached Files Attached Files
  7. #7
    Apr 2007
    Quote Originally Posted by CNC Lurker View Post
    All 16 that I am using have the original button head screws. Going to hex head screws doesn't look as good, but they have two advantages in that the screw cost is probably a few cents less for each screw, and the hex head is easier to get a wrench onto for adjustments.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  8. #8
    Feb 2009
    Thanks Lurker, I think your drawings will work.
  9. #9
    May 2009
    Quote Originally Posted by CarveOne View Post
    CarveOne
    Sorry, I thought they changed them and didn't update the plans since I got the hardware kit from Fine Line Automation for the FLA 3ft x 4ft table and it had hex head bolts. He may have used the hex heads to save cost and make it a bit more affordable.
  10. #10
    Jul 2010
    Are you kidding me??? These are available somewhere on line?
    I spent a 'lot' of time making those profiles from scratch in illustrator....
    [URL="http://www.cnczone.com/forums/cnc_wood_router_project_log/124543-mountaincrafts_router_plasma_build_thread.html"][U]4' x 8' CNC Wood Router Project[/U][/URL]
    [U][URL="http://www.cnczone.com/forums/woodworking/135576-home_made_drum_sander.html"]Home Made Drum Sander Project[/URL][/U]
  11. #11
    Apr 2007
    Actually, I double checked this morning and my big machine's 8 carriages have the button head socket screws and my current build has 8 carriages with hex head bolts. So, I was only half lying.
    CarveOne
    CarveOne
