Page 4 of 20 FirstFirst 123456714 ... LastLast
Results 37 to 48 of 232
Thread: CNC Router Build For A Friend
  1. #37
    Apr 2007
    U.S.
    It seems your manual milling idea was a good one afterall. Did you determine what the Z clearance will be. Will there be a possibility of a coolent addition if one wanted?
  2. #38
    Jan 2005
    Today I started Milling the table T-Slots, Here is some setup information for the Table, The first was to machine one face, Then I used a Edge Finder to pick up that Edge of the Table, I then moved the Mill Table the amount needed for the first T-Slot, A Slot was Milled to the full depth needed for the T-Slot, The T-Slot Cutter was then setup,& the Slot was cut, The next thing to do was to Chamfer the Slot
    Attached Thumbnails Attached Thumbnails CNC Router Build For A Friend-milling_first_face-1.jpg   CNC Router Build For A Friend-using_edge_finder_first_edge_t-slot-2.jpg   CNC Router Build For A Friend-mill_slot-3.jpg   CNC Router Build For A Friend-cut_t-slot-4.jpg
    Mactec54
  3. #39
    Jan 2005
    giz
    The Dmm servo system is an excellent choice, & would be very good for your machine build, we have to look at one thing, I think you will need 6 axes Bob I will check out you build
    sconklin
    The Z axes will have 6.5" Travel, around 7'' under the Gantry
    My idea is to use the Manual Mill as much as I can for this build, as I think most Zone members, can relate to a manual machine that you turn a handle to cut a part a lot better than a CNC machine, This is the starting point on how, a basic machine, can do anything if you have the time
    Mactec54
  4. #40
    Apr 2009
    Talking
    Mactec54
    Great build!! I am always amazed at the machinist skill on this web site. Would you ever consider machig a tslot table for some one else? I have been on the hunt for one for a while now and havent found anything I like yet. I saw yours and its exactly what I need!!
    if not no big deal just thought i woud ask
  • #41
    Jan 2005
    tskguy
    Thanks for your comments on the build
    Yes I can make other T-Slot tables just depends on the size you want, The T-Slot table for this build is .750 thick, & made from Mic6 Tooling plate, there are two ways to make these, they can be Machined like the one in the photo's, or fabrcated which is a good way as well, If you damage a panel, you can just replace the part that is damaged
    The table is now finished so I will post some more photos tomorrow
    Mactec54
  • #42
    Apr 2009
    Wow very cool...
    My machine is a small fixed gantry machine so my current table is only
    12" x 12" It is also mic6 and Im pretty sure .5 inch thick. I could send my existing table or just purchase some new mic6. I have a feeling .5 may be a little thin for tslots. Anyway let me know.
    Thanks!
  • #43
    Jan 2005
    tskguy
    I will be building a smaller machine soon, it to will have a table size around the 12x14, Thicker the better for the Table, even for a small machine it makes a big difference
    We could still use your .500 plate & add the T-Slot pieces to it. the top pieces would be doweled & cap screwed in place from the bottom
    Mactec54
  • #44
    Apr 2009
    Again thanks,
    I sent you a pm but failed to read the part about using my existing table. I really like that idea!! Send me a message and we can chat about details!
    Thanks,
    Eric
  • #45
    Jan 2005
    tskguy
    I replyed to your PM
    There will be more photo's today of the build's progress
    Mactec54
  • #46
    Jan 2005
    Here is some more photos of the finished T-Slot table & the support Base Frame
    Only the end frames to finish & the Main support frame will be complete
    Attached Thumbnails Attached Thumbnails CNC Router Build For A Friend-base_frame_front_view_without_table_front-1.jpg   CNC Router Build For A Friend-base_side_view_without_table_mounted-2.jpg   CNC Router Build For A Friend-base_frame_complete_table_mounted-4.jpg   CNC Router Build For A Friend-base_side_view_table_mounted-5.jpg
    Mactec54
  • #47
    Apr 2007
    That's some pretty spiffy looking machining work. Looks a lot better than my no-frills efforts. I can appreciate just how much effort went into it though.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  • #48
    Jan 2005
    CarveOne
    I watch your builds as well, you are having fun with your builds, that is the important part, I will be building a bigger & a small machine next
    Mactec54
  • Page 4 of 20 FirstFirst 123456714 ... LastLast
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. Build Thread- Building a CNC Router; by someone who can't build a CNC Router
      By Womble in forum DIY CNC Router Table Machines
      Last Post: 09-27-2008, 08:51 AM
    3. Router Using 3/4" MDF (first router build)
      By eguy208 in forum CNC Wood Router Project Log
      Last Post: 04-11-2008, 11:33 AM
