Page 18 of 20 FirstFirst ... 8151617181920 LastLast
Results 205 to 216 of 232
Thread: CNC Router Build For A Friend
  1. #205
    Jan 2005
    iknowyoudo
    The Xaxes rails are 20mm the Y & Z are 15mm, Y & Z linear rails are in machined pockets
    As for the spindle this will be one of mine that I build, ER25 size with a tool changer
    Mactec54
  2. #206
    Oct 2010
    Mactec54,
    Thanks. Can't wait to see the tool changer.
    Eric
  3. #207
    Jul 2007
    Sweden
    Amazing work, Look forward to seeing some more.
  4. #208
    Mar 2011
    Any updates yet ??
  • #209
    Mar 2011
    I guess no more pictures
  • #210
    Jan 2005
    fastpcuser
    Thanks for your interest, more will come, but this will take some time as I have been building other machines as well
    Mactec54
  • #211
    Feb 2004
    Flagstaff,AZ
    Very nice work, please post more pictures when you can. I'm curious as to why you decided to move the rails on the z instead of bearings. Do you have any solid models of the final assembly that you could post?
  • #212
    Jan 2005
    kevincnc
    This is not always easy to implement, but the benefit of extra rigidity is worth it, with having the Bearing at a fixed point, there is no change with the Z axes rigidity over its whole travel, Plus you get the added support of the rails on the moving Z axes spindle mounting plate
    Mactec54
  • #213
    Nov 2012
    canada
    Very nice workmanship! I'm anxious to see how you attach the carriage to the gantry sides...
  • #214
    Registered jsheerin's Avatar
    Aug 2008
    Actually with this Z setup the stiffness of the machine does change as the Z goes up and down. A constant force applied to the tool will apply a varying load to the bearing blocks as the Z changes its position (and thus moment arm length) leading to different amounts of deflection of the tool tip given a constant stiffness of the linear bearing blocks. This leads to a varying machine stiffness with Z height. However I think in most cases it should be stiffer with this setup than with the bearing blocks moving. With moving bearings, you have a constant overhang of the plate carrying the spindle. With the moving rails, you have that same overhang at max Z extension, but at all other Z extensions the overhang is less, leading to a stiffer assembly.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
  • #215
    Jan 2005
    jsheerin
    Thanks for posting
    Yes it does, but if the force measurments that you make are when it is down,( Load/Force= Deflection) & you use those numbers as your max,Before deflection, then it does not change over it's whole travel, you have the same constant load, as it goes up it will be more rigid,as it moves up, but the load/force is unchanged,With testing the moving rails can be up to 60% more rigid,( Built & Tested ) than a Plate & moving bearing type Z axes, the one that is in the photos is 43% stiffer than the normal Zaxes moving bearing type, I have 5 different designs for Gantry type Z axes, A 4 rail Zaxes design I have is by far the best most rigid design, but costs twice as much to build as well
    Yes you do, but the assembly in the posts is 43% stiffer,at max extension than the normal Moving bearing Zaxes, enough to make it more than worth while to build
    The materials I use for these stressed parts, is also much stronger than the regular 6061 that most use, so are able to get higher loading before there is any deflection
    Mactec54
  • #216
    Feb 2004
    Flagstaff,AZ
    I think it depends completely on how stiff your plate with the rails mounted to it is. and how far it hangs down below the bearings. If it's weak (and I'm sure yours will not be) then this setup could be weaker than one with moving bearings. You obviously are doing it right as your testing has shown, but it's possuble that the one you compared it to could have been stiffer also even with moving bearings, right? Do you have a picture of what you compared it to? Sorry to beat this to death but my moving bearing setup is very rigid, and most rigid at the bottom of the travel (picture attached.) I was also trying the keep the spindle as close to the Y-Asis bearings as possible.
    Sorry not trying to hijack your thread, I just think it's an important topic. If you want me to delete my picture I'll do that.
    Now lets see the rest of it finished!
    Attached Thumbnails Attached Thumbnails CNC Router Build For A Friend-z%2520sub-assembly.jpg
  • Page 18 of 20 FirstFirst ... 8151617181920 LastLast
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. Build Thread- Building a CNC Router; by someone who can't build a CNC Router
      By Womble in forum DIY CNC Router Table Machines
      Last Post: 09-27-2008, 08:51 AM
    3. Router Using 3/4" MDF (first router build)
      By eguy208 in forum CNC Wood Router Project Log
      Last Post: 04-11-2008, 11:33 AM
