Page 86 of 221 FirstFirst ... 36768384858687888996136186 ... LastLast
Results 1,021 to 1,032 of 2649
Like Tree15Likes
Thread: CarveOne's Steel Channel Rebuild
  1. #1021
    Apr 2007
    Quote Originally Posted by LouF View Post
    The nails fit right in good choice all in all a very good looking box is that red oak?
    Lou
    Yes, made from 1" x 12" boards from Lowes. A 48" and a 24" piece. Should have bought a single 72" piece. I'll do that for the next one.
    CarveOne
    http://www.carveonecncwoodcraft.com
  2. #1022
    Apr 2007
    Quote Originally Posted by Drools View Post
    Very nice C1! It is hard to tell the scale from the pictures, what are the dimensions?
    Thanks,
    It's 5-1/2" tall by 9-3/4" deep by 13-1/2" wide. Adding the handles brought it out to 15-1/2" wide. It weighs about 7-1/2 pounds.
    CarveOne
  3. #1023
    Apr 2012
    China
    very nice
  4. #1024
    Apr 2007
    Quote Originally Posted by Shirly Liu View Post
    very nice
    Thank you very much!
    CarveOne
  • #1025
    Aug 2011
    UK
    I like that a lot C1
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
  • #1026
    Apr 2007
    Quote Originally Posted by TrickyCNC View Post
    Thanks. The box is a nice design to work with. I highly recommend to make one. It has room for many types of carved designs and no specialty tools are required other than having a CNC router. I posted some of the latest photos over in the Vectric forums in the VcarvePro/Gallery.
    With a horizontal panel inside it could be turned into a really nice router bit case.
    CarveOne
  • #1027
    Aug 2011
    UK
    Quote Originally Posted by CarveOne View Post
    ............ and no specialty tools are required other than having a CNC router................
    Hee Hee. You gotta admit, it's nice to be able to say that !
  • #1028
    Apr 2007
    Yeah, my tongue was planted firmly in my cheek when I said that.
    It's mostly true though, a plain box can be made with a table saw, router, chisel, and hammer. The original floral design can be done with chip carving tools and a lot of skill.
    I prefer having a CNC machine do the chip carving for me. It has no problem doing the really tedious work that I have no skills for and is not as lazy as I am.
    Hard, tedious, work fascinates me. I can sit and watch it for hours.
    CarveOne
  • #1029
    Registered revwarguy's Avatar
    Feb 2009
    Very nice box, C1. I really like the way the c-knot design produces that shading effect that is picked up with the stain. That got my wheels spinning.
    I've been working on something similar. Not to hijack your thread, I posted some pics of it here. Its my attempt at a full 2 cabinet tool chest for my woodworking tools.
    The drawer fronts are similar to your box patterns in that it's a V carve (not 3D) and uses stain, but I also used a color wash on it before the stain, which I think has a nice effect, but I wonder if the shading like you did would have worked.
    Anyway, great job, and I'm sure your recipient will love it!
    "72.6 per cent of all statistics are made up on the spot." - Steven Wright
  • #1030
    Apr 2007
    Wow, that's really nice! Maybe some Celtic wrench knot designs would work. That's what my two steel tool cabinets look like inside each drawer. Everything all mangled together. The only organization is that each drawer in my tool cabinets have a different type of tool in it. At least I know that screwdrivers are all in one drawer (or scattered all over the shop).
    Are all joints in your cabinet glued, or glued and fastened with brad nails?
    I would consider building something similar to your cabinet just for wood chisels and router bits. Currently I have an oak veneer plywood chest I bought at Lowes 15 years ago and the drawers aren't tall enough to stand router bits on the shanks in pockets.
    The 3D Celtic Knot font is a true Vcarve operation from regular vector lines. I suppose the lines that create the shading effect by stepping down a little with each one does it by making each step with closer spaced vector lines. The steps appear to be about 0.005" each. It has a visible rounding effect, and staining the knots enhances the effect. It's a slick way of simulating a 3D effect.
    CarveOne
  • #1031
    Registered LouF's Avatar
    Sep 2011
    I agree the is some great work I think that is a nice project for me to try once I get more advanced..
    Lou
    http://www.cnczone.com/forums/diy-cnc_router_table_machines/140832-new_fla-100_kit_build.html
  • #1032
    Feb 2009
    Some of mine look like a lid was fastened on it while someone took a ball peen hammer and smashed everything up against the lid, and then removed the lid. It's a real hassle
    getting anything in or out and still be able to shut the drawer. Ive been in denial about this too long.
    The joinery is tongue and groove, glued and nailed. Case is 3/4 oak veneer ply with 3/4 oak trim and the drawers are all 1/2 inch baltic birch ply (the thin ply stuff seems to take end-on nails ok) with 1/2 oak drawer fronts.
    Would you mind posting a close up of the vector drawing of the shading area?
    PS Thanks for the tip about the gunstock carving book.
    Rev
  • Page 86 of 221 FirstFirst ... 36768384858687888996136186 ... LastLast
    LinkBacks (?)
    1. CarveOne's Work Table CNC Router Build
      By CarveOne in forum CNC Wood Router Project Log
      Last Post: 05-14-2013, 12:28 PM
    2. mill a V-channel in 304 sst
      By kendo in forum General Metalwork Discussion
      Last Post: 06-12-2010, 01:34 PM
    3. CarveOne's Solsylva 25x37 Router Build
      Last Post: 05-15-2010, 07:08 PM
    4. Steel C-channel Build - Questions and pictures
      By olskool in forum DIY CNC Router Table Machines
      Last Post: 07-07-2007, 02:31 AM
    5. IRC channel for EMC
      By Dan Falck in forum LinuxCNC (formerly EMC2)
      Last Post: 12-18-2004, 12:03 PM
