I hear a lot of warnings about welding on the CNC Zone, and to stay away from it because of warping. My thought is always "Then how have people been building precision weldments all these years?" It's all in how you go about doing it, as in everything else. This frame is not absolutely perfect, but it is my own fault for lack of a good welding jig to hold it straight, and not having the proper gas flow. The MIG gas cylinder was almost empty from building the 12' machine's frame and I used up the last of it this time. I'll get another cylinder in the coming week. Though the frame is off a little it is something that can be compensated for in an acceptable manner.
The procedure that you mentioned is the one that I also use to compensate for "pulling". It works quite well.
I think I am about the only one here that uses vertical X axis rails for my machines that uses cncrouterparts.com bearing carriages. It puts all of the gantry weight on the two bearings in the top carriages that roll on the edge of the rail. The lower carriages don't support any weight, just keep the gantry support square and prevent lifting when plunging the cutter into material being cut. The horizontal rail method that Ahren recommends and FLA uses can support more weight because four bearings in each carriage carry the load.
I haven't had any ABEC7 bearings go bad so far, just wanted to point out this difference.
If you are going to cut steel, then I would recommend using thick wall box tubing for the frame instead of channel as I am doing. It is generally straighter than channel, and 3/16" or 1/4" thick wall tubing will be a lot stiffer. Bevel the edges that are to be welded so that weld penetration is better. That too is a normal welding procedure, as I'm sure you know.
Be sure to post your build here, of course.
CarveOne
16Likes
LinkBack URL
About LinkBacks
I build electrical and hydraulic/pneumatic panels for a day job so I want a rigid setup to do this. Keep up the good work, I will be following your progress.
