Page 2 of 15 FirstFirst 1234512 ... LastLast
Results 13 to 24 of 179
Thread: First Machine Build
  1. #13
    Sep 2010
    Quote Originally Posted by gwsadair View Post
    Even though I have been watching this site for about a year I am just now getting time to put together my first table. Your design looks like something that would not break the bank but be very functional for a first timer. The majority of my planned work is in wood so I do not think I would need something strong enough to handle metal. Biggst problem is where to start. Your unit looks great.
    There are a lot of great ideas out there. I got most of my ideas from Build Your Own CNC Router Machine.
    As far as where to start. Start with the spindle. Pick a spindle that is appropriate for the work that you want to be able to do, and then design the machine to carry it over the cutting area that you need.
    I would suggest not using MDF as a building material. Use a good quality harwood pllywood, or better use MDO.
    Good luck.
  2. #14
    Sep 2010
    Quote Originally Posted by ger21 View Post
    Virtually all those bearings, regardless of the manufacturer, have the same specs. And the bushing have a 1/4" hole, which is larger than 6mm. You might want to check that, as using 6mm may allow the bushing to move a bit. Although, if they're eccentric, and you have them tight, I guess they can't.
    Thanks for the head up Gerry, but don't worry. I ordered the metric bushings from Pacific Bearing.
    J
  3. #15
    Oct 2009
    jharvey
    thanks for the info. I actually have an older fixed base variable speed router that I just rebuilt with new bearings and shims. It has a bit of weight to it, but for accuracy and torque I don't think I will find anything better to start with. Now to start planning table size and all the other good stuff.
  4. #16
    Sep 2010
    jharvey
    Sounds like a good start. Keep us posted on your build.
  • #17
    Sep 2010
    Front View
    Here is a look at the router from the front. I still have a lot of work to do, but it is already running very well and I am using it for work. That accuracy is .010", which works well enough for what I am doing, but I am aiming for .001".
  • #18
    Sep 2010
    Zero Jig
    I built this jig for referencing the control point to zero anywhere on the table. It mounts in a t-slot and has touch plates for X and Y axis.
  • #19
    Registered Zygoat's Avatar
    Feb 2010
    I like that zeroing jig, good idea
  • #20
    Registered CNC Lurker's Avatar
    May 2009
    I was wondering how you used that zeroing jig since the aluminum angle wasn't flush with the corner of the white part.
    This pic explained it (click on thumbnail):
    Which zeroing program are you using?
    (by the way, how did you get a member gallery)
    http://paul-flores.com/
  • #21
    Sep 2010
    Quote Originally Posted by harryn View Post
    Hi, I will be very interested to see how you like the V bearings. I am considering them for a project as well. What size did you end up using ?
    The V bearings are working great. I am using a hardened steel rail from Pacific Bearings and everything is running very smoothly. I am going to add wheel covers and lube wipers soon.
  • #22
    Sep 2010
    In the beginning.
    I've decided to post a build log of my machine starting at the beginning.
    Here is a look at the initial design. Most of the design comes from the Build Your Own CNC Router Machine website and book. I also read a lot of blogs and this forum to collect ideas. The first machine was very simple. It's made of MDF, aluminum angle for rails, V bearings and a simple chain drive system. The Z axis will be lead screw.
    Here is the concept drawing.
  • #23
    Sep 2010
    Torsion box table
    The first step was building the torsion box table. I found that my glass dining room table was actually quite flat. Especially when compared to my work bench, outfeed table and other tables that were available.
  • #24
    Sep 2010
    Z axis tool carrier
    I'm not sure of the names of all of the parts of a CNC router, but I call the part of the Z axis that moves up and down the 'Tool Carrier'.
    The tool carrier is made of MDF with aluminum angle as rails for the V bearings. The angle is held by 1/4-20 oval head machine screws and cross dowels. They are actually quite strong.
    Attached Thumbnails Attached Thumbnails First Machine Build-image017.jpg   First Machine Build-image018.jpg   First Machine Build-image019.jpg   First Machine Build-image020.jpg
  • Page 2 of 15 FirstFirst 1234512 ... LastLast
    LinkBacks (?)
    1. New Machine Build- My Second CNC machine build!
      By Toaster55 in forum DIY CNC Router Table Machines
      Last Post: 06-22-2011, 07:50 PM
    2. Newbie- My first CNC machine - Build
      By clocksandblocks in forum DIY CNC Router Table Machines
      Last Post: 03-06-2010, 11:35 AM
    3. New Machine Build
      By skipper_52 in forum CNC Wood Router Project Log
      Last Post: 04-07-2008, 07:13 AM
    4. Use the second machine to build the first!
      By Madclicker in forum CNC Wood Router Project Log
      Last Post: 06-27-2007, 12:29 AM
    5. Want to build new machine
      By thuffner3 in forum CNC Machining Centers
      Last Post: 02-14-2004, 09:47 AM
