Page 1 of 4 1234 LastLast
Results 1 to 12 of 39
Thread: 4X4, R&P, 8020, FLA300
    Registered k4mg's Avatar
    Jun 2008
    I contacted Fine Line Automation (FLA) on 11/19/2010 with several questions about their FLA300 4X4 complete kit. Nate and I had 3 e-mail conversations, and all answers came within 2 days. I ordered the complete kit as well as 4 axis power using the G540 on 11/27/2010. Nate said the kit would ship between the 10th and the 15th, and it did.
    I have never built a CNC machine, but I have owned 4 of them within the last 3 years, and still have 3, a woodworking Shopbot Buddy CNC router, a metalworking Syil X4 CNC mill, and a metalworking Syil C6B CNC lathe.
    I started out intending to build a woodworking machine, and ordered the plans for the JoeCNC 4x4 Hybrid. After considerable drooling over the plans, I decided I lacked the confidence to build one, and instead ordered the Romaxx HS-1, a small, very well built steel and aluminum cnc router. I learned cnc on this machine, but after a year or so, I sold it and bought a Shopbot Buddy BT-48 with a 4’ Powerstick. My problem with the Romaxx was I kept on making small furniture models on the Romaxx, like chairs and stools, while lusting to make full size ones, hence I bought the Shopbot.
    I still have the Buddy, and it is an excellent machine, but I am now into indexer work, and want to cut dovetails. I built an indexer for the Buddy using my 2’ Powerstick, but want a 4’ one.
    This got me back looking at the JoeCNC plans again, but I still have concerns about the MDF parts here in humid Florida, so I started researching 8020 machines.
    I first found CNCRouterParts, then FineLineAutomation, and I ordered the full kit mentioned above. What follows will be my build log for the FLA300.
    Barry
    Jun 2008
    First Boxes Arrive!
    First 5 boxes arrived 12/15/2010, all the 8020, linear rails, and rack. Two more scheduled to arrive 12/17 with hardware and electronics. Only one dinged aluminum piece that I saw, and it is on a support piece that can be turned under so no problem.
    Everything was very well packaged, when there were different length pieces, they were wrapped in plastic, the ends of the boxes were protected with high density foam, and the boxes were filled with peanuts. All the parts had labels.
    Attached Thumbnails Attached Thumbnails 4X4, R&P, 8020, FLA300-img_0508.jpg   4X4, R&P, 8020, FLA300-3030_img_0510.jpg   4X4, R&P, 8020, FLA300-1530_rack_rails_img_0512.jpg
    Jun 2008
    Next 2 boxes arrive, hardware and electronics
    Last 2 boxes arrived on 12/17/2010 and were the electronics (except for the G540 controller), and the hardware. I have emailed Nate about the G540 not being in the shipment.
    Attached Thumbnails Attached Thumbnails 4X4, R&P, 8020, FLA300-img_0518.jpg   4X4, R&P, 8020, FLA300-img_0517.jpg   4X4, R&P, 8020, FLA300-img_0514.jpg   4X4, R&P, 8020, FLA300-img_0516.jpg
    Jun 2008
    Z Axis
    12/18/2010. Only loosely screwed together because I need the steel plate to assemble the carriages, and I want to paint the rails.
    Jun 2008
    Linear Carriages and R&P Drives
    12/19 2010 Assembled carriages and the R&P sub-assemblies.
    Attached Thumbnails Attached Thumbnails 4X4, R&P, 8020, FLA300-img_0526.jpg   4X4, R&P, 8020, FLA300-img_0525.jpg
    Jun 2008
    Bed with legs
    12/21/2010 I am using roll-in nuts for my spoilboard, so don't need any hardware in the cross-members. I can't put the rails on until I square everything, and I have to put the brackets on to help with that.
    Jun 2008
    Y Linear Rails and Rack
    12/24/2010 Everything appears to be square and the bed is equally down as near as I can measure. Using a simple Harbor Freight roller from my table saw helped a lot getting the Y 3030 and rails on.
    I have moved the Y rails two inches from the front to be able to cut mortise and tenon joints and use an indexer on the front of the table. I have the rack just fastened down with one bolt until I get the gantry on and discover the positioning needed.
    Jun 2008
    Finished Y axis and Y R&P, fully assembled Z
    12/25/2010 Caught up to real time now. Did this work in about 3 hours today. Tomorrow I will hopefully mount the Z, and give some details about my experiences using the drawing and the BOM. I installed the bearing block backwards from the plans because the drill rod projections fit better this way. Y axis is 1/4" off side to side, will check tomorrow.
    Attached Thumbnails Attached Thumbnails 4X4, R&P, 8020, FLA300-img_0535.jpg   4X4, R&P, 8020, FLA300-img_0536.jpg   4X4, R&P, 8020, FLA300-img_0537.jpg   4X4, R&P, 8020, FLA300-img_0541.jpg
    Jun 2008
    X Axis squaring and R&P, Mounted Z Axis
    12/26/2010 Mounted X Axis R&P, mounted Z Axis assembly and router. Loosened Y axis rail (each rail was only held in place by one bolt), moved rail and racks to final position 2" from front to facilitate doing dovetails and an indexer from the front of machine, and ran Y axis back and forth to center everything, then tightened down front bolts on Y rack, which is out of square by 1/4". Will look for problem Tuesday, 12/28, when I can get back to this. Then will bolt down both the Y rails from the center out to flatten them, and tighten rack bolts.
    X and Y move smoothly by hand and Z moves by turning coupler, and was set up perpendicular to the bed using a square. May have to re-do Z squaring after I find Y problem.
    How I adjusted and squared the Z axis (last 3 pictures below):
    • Put all accessories on Z and 2 pieces of 3/4" ply to represent my base and spoilboard.
    • Put in my shortest tool.
    • Cranked Z all the way down until within 1/4" of bottom of rail.
    • Clamped the carriages square in alignment.
    • Used a machinist square and aligned the assembly.
    • Adjusted everything until tool just touched spoilboard, then tightened the 4 nuts.
    This completes the mechanical assembly of machine. Next is cabling and electrical.
    Attached Thumbnails Attached Thumbnails 4X4, R&P, 8020, FLA300-img_0559.jpg   4X4, R&P, 8020, FLA300-img_0554.jpg   4X4, R&P, 8020, FLA300-img_0557.jpg   4X4, R&P, 8020, FLA300-img_0549.jpg
    Jun 2008
    Comments on Drawings, BOM, the FLA kit, CNCRouterParts, and FLA Communication
    Drawings:
    The drawings are the best set of plans I have ever used. Once I became somewhat familiar with how to use the SolidWorks viewer, I was able to find everything I needed to build the machine quickly and easily. The only thing I haven't figured out is point to point measuring, like the distance the rack was offset from the front of the machine. Sometimes I could set two points, and then got the distance, but more often I got an entire strut length. No doubt this is my poor understanding of how to measure ptp.
    I didn't find anything in error in the drawings. I am sure the drawings follow some standard when they use a part number for the bolts, but in my opinion, if they simply used the bolt type and length (I.E. BHCS, 5/16-18, 2.5) like is used for the 8020, the plans would be easier to use directly, instead of having to refer to the BOM to determine the bolt length. Of course, the type can be determined by the shape in the drawing.
    BOM:
    I found the BOM to be full of errors and missing information. As an example, the two bolts that hold the Z axis zero backlash nut are not in the BOM and were not supplied in the kit. The R&P is in the BOM, but only as an assembly, not with the individual parts listed. Most of the needed R&P hardware is bagged together, but not all. I got parts in bags I didn't know what to do with, and some full (unused) bags are still left after the assembly is complete. This is very frustrating because the brtech write-up, which helped me immensely, mentions many of the problems that I also had, and it was from September. Supposedly Nate of FLA fixed the plans from the brtech build. I asked Nate for the updated set on 11/29, when I first found problems in the BOM, and he told me he would update his website with the corrected version by 12/5, but the plans and the BOM are the same one I think brtech worked with, and FLA has never provided the update.
    The FLA Kit:
    The 8020 went together perfectly, all lengths were correct, all holes were in the exact place they should be, and all the tapped holes were good. I couldn't be more pleased.
    CNCRouterParts carriages and R&P:
    These components were of the highest quality and worked perfectly. The Z axis assembly diagram, the carriage assembly and adjustment video, and the R&P assembly video on Ahren's website clearly showed assembly and alignment information, and were all I could ask for. I asked Ahren several questions via email, and got immediate responses.
    FLA Communication:
    • On 12/17 I advised FLA via email my G540 controller was not in the shipment, and requested he ship it to me.
    • On 12/17 I again requested via email the updated plans because of drawing to BOM cross-reference problems I was having.
    • On 12/18 I advised FLA via email of missing parts, and requested he ship them to me.
    • On 12/18 I advised FLA via email that the Z axis radial bearing in the bearing block, with the drill rod inserted, turns with a definite bump, like it had a flat ball bearing, and asked is this a problem and should I use it.
    • On about 12/22 I called FLA to again ask about my missing G540, and left a message.
    As of this date, 12/26, I have had no responses to the 4 email questions or the call. I sent another email this A.M. about the missing G540. I just called Nate but again got his answering machine.
    Jun 2008
    FLA Communications
    Today I got a very nice email from Nate of FLA apologizing for being non-responsive, and also promising to ship out the G540 today. He offered me a $100 refund for my problems. As it turns out, he was on vacation for the last two weeks.
    I am very pleased with the kit I bought and consider it a great value, and have advised him I don't need the $100, I just need the G540.
    Barry Rimmer
    Jun 2008
    Y Axis off 1/4" fixed
    I used the ends of the Y rails as a reference, lined up the longer end of the gantry with the end of the Y rail and blocked it in place, loosened all 4 bolts on both sides, and moved the short side up to the end of the Y rail, tightened everything, and am now less than 1/32" out of square. I'll leave it like this until I get my G540, and draw some squares to check overall alignment.
    I'm very happy!
  • Page 1 of 4 1234 LastLast
      By oneturboneeded in forum Alibre Design
      Last Post: 04-24-2010, 11:51 PM
    2. Why use 8020?
      By DPF in forum DIY CNC Router Table Machines
      Last Post: 04-23-2010, 05:29 PM
    3. cad to do 8020
      By oneturboneeded in forum General CAD Discussion
      Last Post: 04-22-2010, 10:17 PM
    4. Need Help!- What is the best way to cut 8020?
      By brihoo2k in forum DIY CNC Router Table Machines
      Last Post: 03-12-2010, 10:44 PM
    5. Newbie- Help w/8020
      By Jcyr1 in forum DIY CNC Router Table Machines
      Last Post: 09-03-2008, 03:04 PM
