Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 07-08-2005, 04:23 PM
raiven is on a distinguished road
My first router - Finally!
Hi all,
I've attached a few pictures of my router. The first phase of building is complete. The grounded rods and the threaded rod for the X-axis have been mounted. I opted for the plan from Michael Walach .
It's a tabletop router with a moving table. It's supposed to be build from Delrin but I couldn't find any here so I opted for what I had lying around. I build subwoofer enclosures and have plenty of 10mm clear acrylic sheet. I converted all imperial units to metric (more or less) and designed my own linear bearings (which are in the process of being completed). I took the plexi to a local lumberyard and asked them to cut it for me. 30 minutes and 2 Euro's ($2.5USD) later (cheapo!) all my parts were cut to the millimeter. It took me three evenings to get this far. I've got 2 weeks of leave so that means plenty of time to spend in the shop! I'll keep the updates coming.
Greetzzz,
Dimitri
ID:	8638   Click image for larger version
ID:	8639   Click image for larger version
ID:	8640   Click image for larger version
ID:	8642   Click image for larger version
Old 07-08-2005, 11:58 PM
ViperTX is on a distinguished road
The results will be interesting, keep us updated!...isn't it rather difficult to drill acrylic without "crazing or chipping" it....
Old 07-11-2005, 12:08 PM
Not if you "modify" your drills. I use ordinary metal drills which I dulled a little. This prevents the drill from "grabbing". Also you've got to keep an eye on the drill speed. If you go too fast you'll melt a hole in stead of drilling one. I'm more worried if the acrylic can stand the forces applied to it when I'm going to route things on it. If it does, excellent, if it doesn't then this was an excellent way to refresh my machining skills. I'm off to the shop and will probably post the pictures of today's work later on.
Greetzzz,
RaiVeN
Old 07-12-2005, 02:13 AM
abasir's Avatar
abasir is on a distinguished road
Would be great when it's completed. May be you can snap a lot of photos and some videos. Since it is transparent, you can see what's going where and how each component interacts. Good for CNC101 type FAQs.
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
Old 07-21-2005, 11:53 AM
Progress!!!
Hi all,
Sorry for the delays but it has been hectic here. But I managed to spend some time in the shop. I finished the linear bearings for the X-axis and mounted the table onto the rails. It runs so smooth that it keeps drifting off to the left side because the stand it's on is not level. Nice!
I will finish the AB nut today and hopefully connect the stepper so I can shoot some videos of the X-axis moving. For now here are the obligatory progress pictures. Enjoy!
Dimitri
ID:	8882   Click image for larger version
ID:	8883   Click image for larger version
ID:	8884   Click image for larger version
Old 07-22-2005, 09:30 PM
damae's Avatar
damae is on a distinguished road
I spoke to a local plastics supplier yesterday and asked about the machinability of several different plastics. They suggested that cast acrylic will machine nicely, but extruded grade acrylic won't.
And last week, a rep from Garr tools visited me and suggested that I use a diamond coated end mill to cut acrylic and avoid melting. Actually, he was suggesting it for dry-cutting aluminum. But it aparently works very well for acrylic too.
Old 07-22-2005, 09:31 PM
damae's Avatar
By the way, Raiven, your project is looking very nice! The acrylic should look vey stylish when finished. =)
Old 07-24-2005, 03:16 PM
Thanks for the comments guys!
I managed to get the X-axis moving for the first time using turbocnc (3000hz at 1/2 step). I made a video of it but it won't upload (too large, have to find a way around this).
I noticed that the table has the tendency to "twist". After some pondering I noticed why: I mounted the linear bearings the wrong way around! I disassembled the entire table and started reassembling it again. I will test it tomorrow (no PC on site today) to see if the "twisting" is gone.
Dimitri
Old 09-01-2005, 06:23 PM
Hi everybody,
It's been a while since my last update but I managed to get some work done. Everybody wants a new sound system when it's summer. On the bright side this helps finance my router so it ain't all bad
I fixed the AB nut. It ran a little rough but after some work is running smooth.
While out of hex bolts one night, I made supports for the limit/home switches as a test. They came out pretty nice so I'm going to keep the design. I'll need to make 4 more for the Y and Z axis.
I finished the motor mount for the X-axis. I had to add some toothed rings (I don't know the correct english term) to keep the nuts from coming loose due to the motor's vibrations during slow moves.
And finally I completed the fixed gantry. The router is finally starting to look like the machines I see on the forum! There are 2 pictures of the gantry. One with the protective foil still on and one after I peeled it off (which took about an hour due to the foil being hardened by sunlight). I still need to align the rods but for that I first need the Y-axis basis. I am in the process of making the linear bearings. I opted for a different design this time. I took a close look at the table and noticed that it can flex a little when a large force is applied sideways. I figure that the weight of the Z-axis, the dremel and stress while cutting might be a bit too much. I took the design from jgro's plans (thanks by the way!), converted them to metric and modified them to fit my rod/bearing combo. They are coming along nicely but I forgot to take the camera with me to the shop today :-(
I attached some pictures of the work completed so far.
enjoy!
Dimitri
ID:	9881   Click image for larger version
ID:	9882   Click image for larger version
ID:	9883   Click image for larger version
ID:	9885   Click image for larger version
Old 09-01-2005, 08:05 PM
xairflyer's Avatar
xairflyer is on a distinguished road
Interesting to see you using acyrlic, big fan of polycarbonate myself, have thought about building a another machine out of it, rather than aluminium as it is so nice to work with, plus I could cut the bits out on my other machine !.
  #11   Ban this user!
Old 09-08-2005, 07:00 PM
It's alive!
It works!
I managed to finish the Y axis. It took some time to "dial" it in since I don't have the proper tools for that. I have been looking in the local stores but couldn't find one. Does anybody know where to get a dial online?
I hooked both the X and Y axis up to the hobbycnc controller. With a few pieces of acrylic and some glue clamps I managed to fix a pencil to the Y axis. I have to admit I got pretty nervous when I executed the first piece of g-code. My finger never left the escape button!
Even with one axis still missing and a simple piece of paper and a pencil the result was pretty nice. Only a pitty that the pencil was fixed and the line fades after a few centimeters. I've attached a picture of the setup and my first result. I can't wait to finish the z axis and cut my first part.
Dimitri
ID:	10018   Click image for larger version
There are no problems...only challenges
  #12   Ban this user!
Old 09-09-2005, 10:26 AM
Jason Marsha is on a distinguished road
Congrats, Keep the pics coming and a video if you can.
Jason
Finally Started My Router Project Ozinus CNC Wood Router Project Log 19 07-18-2005 06:46 PM
finally a done deal ...... strat DIY-CNC Router Table Machines 6 04-21-2004 12:41 PM
Finally starting on router project ehiebert DIY-CNC Router Table Machines 9 04-10-2004 08:07 PM
