Page 1 of 6 1234 ... LastLast
Results 1 to 12 of 70
Thread: Upgrading another WidgitMaster router
    Gold Member widgitmaster's Avatar
    Jun 2005
    I've been using this router for over two months now, and I have noticed a weakness or design flaw in the lower y-axis slides! I had made the entire router using IKO LWL12B linear rails, and its obvious now that 12mm is not strong enough for the X & Z-axis weight!
    My solution is to remake the lower section and use THK HSR25CR linear slides. These 25mm slides are designed to take force in all directions, and have a nice grease fitting to lubricate them!
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0933.jpg   Upgrading another WidgitMaster router-100_0934.jpg   Upgrading another WidgitMaster router-100_0935.jpg   Upgrading another WidgitMaster router-100_0936.jpg
    Jun 2005
    After spending a few days in CAD, I came up with a simple solution. Then I placed an order for materials, and choose a 6"x6" aluminum angle with 3/4" wall thickness. This is much more economical than hogging out a large rectangular block of 6061!
    The front & rear plates will be made from ALCAST-5, which is the Canadian equivalent of MIC-6 jig plate! The Canadian plate is much nicer material to work with, as it is not a chalky or powdery as MIC-6! It works much like 6061!
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0938.jpg   Upgrading another WidgitMaster router-100_0939.jpg   Upgrading another WidgitMaster router-100_0940.jpg   Upgrading another WidgitMaster router-100_0941.jpg
    Jun 2005
    Next I made a simple layout of the leg lengths on the aluminum angle, by adding .300" to each dimension. Then I pushed them through the vertical band saw, using lots of wax to keep it cutting smoothly.
    With all the excess material removed, I now need to setup the mill for facing the outer surfaces to get an accurate 90 deg. corner!
    By using two little angle plates, I dialed them in so they are parallel to the table's travel. Then I mounted my BIG Chinese 5" dia carbide face mill, I have found it works better if I take 3 of 6 inserts out!
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0942.jpg   Upgrading another WidgitMaster router-100_0943.jpg   Upgrading another WidgitMaster router-100_0944.jpg   Upgrading another WidgitMaster router-100_0945.jpg
    Jun 2005
    With all the outer surfaces milled flat and 90 deg., its time to mill the length of the long leg.
    So I placed the angle flat on the table, with the short leg against the cast iron angles. Using a 1/2" end mill, I milled the length to print size, then I used a large 2-flute end mill with a .1 radius on the points to mill the step on the inside surface of each part.
    That's enough for one day, as my hands hurt too much to continue!
    Widgit
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0947.jpg   Upgrading another WidgitMaster router-100_0948.jpg   Upgrading another WidgitMaster router-100_0949.jpg   Upgrading another WidgitMaster router-100_0951.jpg
    Jun 2005
    This morning I finished milling the short leg on both parts, and decided to mill the two plates using the current mill's setup!
    That went quick, but I was unable to mill the slots on the inside of the short leg to hold the linear rails. That needs to be done in a different setup!
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0957.jpg   Upgrading another WidgitMaster router-100_0958.jpg   Upgrading another WidgitMaster router-100_0959.jpg   Upgrading another WidgitMaster router-100_0960.jpg
    Jun 2005
    Now its time for the fun stuff!
    In order to mill the ends of the rail supports, I need to rotate the mill's turret and extend the ram! So I placed my 6x9x12 angle plate on the mill's table, and clamped it slightly. Then I mounted my long side plate to the angel plate, and clamped the rail support in the corner.
    This gives me a rough idea of how much travel I need, and where to position the spindle.
    Next I tightened all the bolts on the mill's turret and ram, and removed the cast iron angle plate. Because the table is extended and the turret is rotated, the mill's head needs to be trammed in it's new position. So I used an indicator holder in the spindle and a 1-2-3 block.
    The indicator must be perpendicular to the ram, not the mill's table!
    Next I repositioned the cast iron angle plate, and dialed it's face parallel to the mills table. Now I can use a 3" face mill to cut the entire end surface in one pass. So I milled one end of each part.
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0961.jpg   Upgrading another WidgitMaster router-100_0962.jpg   Upgrading another WidgitMaster router-100_0963.jpg   Upgrading another WidgitMaster router-100_0964.jpg
    Upgrading another WidgitMaster router-100_0965.jpg   Upgrading another WidgitMaster router-100_0966.jpg   Upgrading another WidgitMaster router-100_0967.jpg   Upgrading another WidgitMaster router-100_0968.jpg
    Jun 2005
    With one end finished, I used my big height gage to set my little height gage while it was on top of two 4" cubes! This is the only way I can reach something 18.8007" tall with a 12" height gage!
    With the scribe height set, I marked the unfinished end of both parts. There is over an inch of extra metal, so I will band saw the bulk off and finish the parts in the mill.
    Thats enough for today!
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0970.jpg   Upgrading another WidgitMaster router-100_0971.jpg   Upgrading another WidgitMaster router-100_0972.jpg   Upgrading another WidgitMaster router-100_0973.jpg
    Apr 2007
    Great sequence of instructional photos, as always, from the great WigitMaster!
    But tell me Wigit, is that pair of pipe wrenches on the pegboard precision made and calibrated by Brown and Sharpe? Got lots of chuckles seeing those hanging there.
    Edit: Oops! there's just one pipe wrench. The other one looks like bolt cutters. Even funnier.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Jun 2005
    LOL!!
    Thanks Carv'e!
    Yea, they were my Dad's, and I must admit they don't get much use!
    Widgit
    Jun 2005
    This morning I drilled, tapped & reamed all the end holes. This didn't take long, as the mill was nicely setup for milling the ends!
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0974.jpg   Upgrading another WidgitMaster router-100_0975.jpg
    Jun 2005
    With all the end work done, I can tear down the setup and put the mill back to normal position!
    After tramming the head again, I cleaned off my vises and put them on the mill table. Then I looked around for the long dual vise soft jaw set, they were scattered everywhere!
    With the vises floating loose on the table, I attached the long jaw to both vises. Then the two shorter ones. Next I closed the vises on a ground steel plate to align a preexisting milled step in the jaws. Then I moved the mill table to the center of travel in the long direction, and positioned both vises so the spindle was in the middle of the long jaw.
    Next I loosely bolted the vises to the table, and tightened the furthest nut on the left. With a dial indicator, I trammed the back jaw within a few thousandths, and locked all the mounting screws tight!
    Using a round steel bar, I tightened both vises and milled the step in the back jaw. Then the front jaws.
    Now the vises are ready to hold parts!
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0976.jpg   Upgrading another WidgitMaster router-100_0977.jpg   Upgrading another WidgitMaster router-100_0978.jpg   Upgrading another WidgitMaster router-100_0979.jpg
    Jun 2005
    Before I can start working on the parts, I need to set the DRO to zero on the back jaw!
    Next, I used a long 3/4" 4-flute end mill to make the slot for the linear rails. This did not take long, so I started drilling the holes for the M6 threads. After tapping them, I drilled and countersunk the three holes for mounting the router to it's table.
    A good day's work, and the first two parts are finished!
    Attached Thumbnails Attached Thumbnails Upgrading another WidgitMaster router-100_0981.jpg   Upgrading another WidgitMaster router-100_0982.jpg   Upgrading another WidgitMaster router-100_0983.jpg   Upgrading another WidgitMaster router-100_0984.jpg
    Upgrading another WidgitMaster router-100_0985.jpg   Upgrading another WidgitMaster router-100_0986.jpg   Upgrading another WidgitMaster router-100_0987.jpg
  • Page 1 of 6 1234 ... LastLast
    1. Widgitmaster Wide-Router
      By Jay C in forum Commercial CNC Wood Routers
      Last Post: 12-12-2010, 12:05 AM
    2. New Machine Build- Thinwater builds the Widgitmaster Midi Router
      By Thinwater in forum CNC Wood Router Project Log
      Last Post: 11-26-2010, 03:21 PM
    3. WidgitMaster Midi router on ebay
      By rrrevels in forum CNC Wood Router Project Log
      Last Post: 07-29-2010, 08:08 PM
    4. Replies: 0
      Last Post: 12-09-2009, 04:53 PM
    5. widgitmaster available
      By travrt in forum PCB milling
      Last Post: 07-11-2009, 01:17 PM
