Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 06-26-2005, 06:41 PM
Ozinus's Avatar
Ozinus is on a distinguished road
Finally Started My Router Project
Well the first CNC Router that I built was Ugly, out of alignment and adjustment, Slow and flexed too much.
But now since finding this site I have a renewed urge to build one that is more acurate and more asthetically pleasing.
I have Jgro's plans and I am using them as a guide (Thank you Jgro).
Parts:
24v 12a Power Supply
Dave Kush (Buildyouridea.com) Arcsin Controller
270 oz nema 23 Steppers
Lead screws are 3/8-16 (Temporary)
I will try to post some pictures as I go, as you will see I am not much of a wood worker but I am getting better and I am enjoying it too.
Name:	My Router 005 1000x749.JPG‎
ID:	8388   Click image for larger version
Name:	My Router 012 1000x749.JPG‎
ID:	8389   Click image for larger version
Name:	My Router 015 1000x749.JPG‎
ID:	8390   Click image for larger version
Name:	My Router 016 1000x749.JPG‎
Old 06-29-2005, 11:45 AM
Jason Marsha is on a distinguished road
Good start. Keep the pictures coming. After running 1/4" - 20 threaded rod on my JGRO I am considering changing to 3/8 - 16. Let us know how it works out.
Jason
Old 06-29-2005, 03:46 PM
Gold Member
CJL5585 is on a distinguished road
Dave's Arcsine Controller
I have followed the design of Dave's controller. Keep us posted as to how you like it etc.
Jerry
Old 06-30-2005, 10:31 PM
Ozinus's Avatar
Got a Chance tonight to cut some more MDF for the Gantry, Also won some THK linear rails on e-bay which I am going to use on the Z axis.
Jason- I am using the 3/8-16 just to start I may try 1/2-13 if the steppers are powerful enough.
Jerry - I like Dave's controller though I have only spun the motors using the joystick so far, I am hoping that it will spin up the motors fast enough to get reasonable speed
Mark
Old 07-01-2005, 08:50 PM
Ozinus's Avatar
Got a bit more done today X axis runs quite freely and I am happy with it, of course the rails will have to be adjusted so they a parallel with the cutting table. The Gantry seems to be fairly rigid however I am going to add some bracing vertically on the outsides of the Gantry sides (Just to help).
I am still waiting for the THK Linear rails to come from e-bay that will hold up building the Z axis.
Photos Below are just work in progress (Excuse the mess didn't clean up before I got the camera)
Ozinus
Name:	My Router 017 1000x749.JPG‎
ID:	8466   Click image for larger version
Name:	My Router 019 1000x749.JPG‎
ID:	8467   Click image for larger version
Name:	My Router 020 1000x749.JPG‎
ID:	8468   Click image for larger version
Name:	My Router 021 1000x749.JPG‎
Old 07-03-2005, 03:51 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
Originally Posted by Ozinus
Parts:
Oz,
I don't think you'll have any trouble with a larger lead screw. I'm running 1/2 -10 Acme with 100oz steppers and a 24v 4.5a power supply. I'm able to get 60 ipm reliably.
How do you rate your experience withe the Arcsin Controller plans? I built his original pikeresque plans and it seems to work great so far. However the plans weren't detailed. All I got was a PCB layout and a parts list when I ordered it. Your contoller box looks very nice. Did the plans describe how to build it?
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
Old 07-03-2005, 08:44 PM
Ozinus's Avatar
The Arcsin comes completly assembled and tested from Dave the quality and workmanship is first rate, Dave aslo sells a kit which contains the joystick and logic power supplies, The manual that comes with it is quite detailed and Dave is also quick to respond to any e-mails if you have questions.
I have mocked up the X & Y and I am in the process of stripping it back down to glue and paint it, once my linear rails arrive I will finish the Z then I will be able to test the Arcsin and evaluate it, as I had said I spun the motors using the joystick and it seemed to work flawlessly.
Ozinus
As for the box I just assembled it out of a steel electrical box that I had laying around, once the machine is up and running I will cut out a new one that looks a bit more professional.
Old 07-06-2005, 06:17 PM
Ozinus's Avatar
Originally Posted by mvaughn
Oz,
I tested the speed of my y axis before pulling it apart and I measured 32 ipm at max speed of the steppers with Daves controller using the manual joystick so I am assuming that if you are getting 60 ipm with 1/2-10 your motors are spinning faster than mine and I also think that I will have to cut at a much slower speed than the 34 ipm so I can maintain torque on the motors, I will be more informed once I have the controller hooked up to the computer.
Still waiting on linear rails from e-bay he finally answered my e-mails and said he has sent them today (1 week after I paid for them) some people are just slow I guess.
I found that my y axis bearing trucks are not quite parallel with the rails so I have shimmed the narrow side with some brass shim and they are now aligned much better, I will definatly be cutting out my next machine with the cnc to avoid these misalignment problems.
Ozinus
Old 07-06-2005, 06:36 PM
mvaughn's Avatar
Moderator
Oz,
For me, a boost in voltage with a better quality power supply made all the difference in the world. I started with a PC power supply from a scrap computer that could barely spin one motor at 15 ipm speeds with the 1/2 - 10 tpi leads.
Hooking up more than one motor would trip the internal overload protection of the power supply and shut it down.
I purchased a 24 volt PS rated at 4.5 amps and have gotten much better performance and speed. I don't think my current MDF machine could handle cutting at 60 ipm, but for rapids it's no problem.
Have you checked to see what voltage and amps are reaching your steppers. They should be able to spin a steeper lead screw at lower RPM to get better speeds. The torque will drop off at higher RPM's, if you lowered the RPM's and went with a 10 tpi lead screw you might have good results.
-Mark
Mark
Old 07-06-2005, 06:58 PM
Ozinus's Avatar
Mark
My power supply is a Condor 24v 12amp on my amp meter it draws about 2 amps while running the motor and the voltage stays at 24.
I will try it out with the allthread and the next I will try to get some ball screws
Ozinus
Old 07-06-2005, 11:23 PM
spalm's Avatar
Gold Member
spalm is on a distinguished road
Looking Good!!
Just a few comments.
You are already set up for 3/8 inch lead screws. Why not switch to 3/8 inch 12 turn ACME? You will get a 25% increase in speed and they are more efficient. Speed is always great to have when you need it; (just like a car) you don’t have to use it, or don’t run it fast but it keeps the lead screws from whipping because the RPMs are lower. It is pretty cheap from MSC and they have nuts too for the bearings. You will have to make new anti-backlash nuts though. I was getting burn marks on some cherry when making rosettes until I cranked it up.
I noticed that you have a modification with the side bars running the length of the machine. These would be a great place to add a center support (or more) for the long pipe.
Keep it up,
Steve
  #12   Ban this user!
Old 07-10-2005, 12:38 PM
Ozinus's Avatar
Painted and partially assembled X & Y moving under stepper power, The guy I have bought the linear rails for my Z is super slow, He said he sent them Thurs and would send me a Tracking # on Friday but he did not, I will definately not be buying anything from him again.
I do hope that they are sent and that I will get them this week so I can finish my Z axis.
I have attached a couple of photo's, Not very good quality because of the light in my Garage and the clouds from Hurricane Dennis.
Ozinus
Name:	Copy of My Router 024small.JPG‎
ID:	8660   Click image for larger version
Name:	Copy of My Router 025small.JPG‎
ID:	8661   Click image for larger version
Name:	My Router 026small.JPG‎
Another new router project acondit CNC Wood Router Project Log 144 07-29-2009 07:09 PM
Almost done with 1st Router project..phewww Beezer CNC Wood Router Project Log 42 03-27-2005 06:39 PM
Finally starting on router project ehiebert DIY-CNC Router Table Machines 9 04-10-2004 08:07 PM
Another Router Project pminmo DIY-CNC Router Table Machines 12 12-25-2003 06:26 AM
I finally started building! chuckknigh DIY-CNC Router Table Machines 16 07-10-2003 09:12 AM
