Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 45
Thread: Frankenbot CNC Router
  1. #25
    Jul 2010
    Quote Originally Posted by ger21 View Post
    If the rails are parallel, you could have just let the machine flatten it.
    Nice work so far. I've got a bag of dowel nuts I'll be using on my next build. Do you think you'll need to use Locktite on them? My concern is that they may get loose over time?
    The Y Axis wasn't long enough to span the table with the rails mounted on the outside of the base. So this temporary gantry sled proved to be the easiest and fastest way to flatten to top. And it only took about half a day to build the sled and router the top flat.
    I'm becoming a big fan of dowel nuts! You'll notice I used them to hold together the temporary gantry as well. I doubt they'll loosen over time but a drop of locktite during final assembly couldn't hurt.
  2. #26
    Jul 2010
    Progress
    Now that the table is flat, the X Axis rails have been attached and the Y axis gantry assembled. The bearing blocks for the X and Y axises have been machined. I choose to use 1/2"-8 4-start (.500" lead) lead screws from Roton with anit-backlash nuts from DumpsterCNC. I turned the ends of the lead screws down to 3/8". The bearing blocks hold 3/8" bore ball bearings for the rotational movement, needle thrust bearings and shaft collars transfer longitudinal force to the blocks, which are anchored securely to the ends of the linear rails. The turned ends of the lead screw project about 3/4" out of the backside of the bearing blocks for attachment to the couplers.
    Attached Thumbnails Attached Thumbnails Frankenbot CNC Router-crw_3199.jpg   Frankenbot CNC Router-crw_3181.jpg   Frankenbot CNC Router-crw_3184.jpg   Frankenbot CNC Router-crw_3185.jpg
    Frankenbot CNC Router-crw_3187.jpg   Frankenbot CNC Router-crw_3192.jpg   Frankenbot CNC Router-crw_3193.jpg   Frankenbot CNC Router-crw_3197.jpg
  3. #27
    Jul 2010
    It's Alive!
    Well, the X and Y Axises are at least. It's pretty exciting to see it moving back and forth under power. The 387 oz. steppers are hooked up with helical couplers. I've wired up limit switches at both ends of each axis. Even though I'm using Soft Limits, it's nice to have the back up should I do something stupid like turn the Soft Limits off in Mach 3. The limit switch at the drive end also doubles as a Home switch. Pretty clever of Mach 3 to know how to read the signal depending on what it's doing.
    Attached Thumbnails Attached Thumbnails Frankenbot CNC Router-crw_3203.jpg   Frankenbot CNC Router-crw_3206.jpg   Frankenbot CNC Router-crw_3208.jpg   Frankenbot CNC Router-crw_3207.jpg
  4. #28
    Jul 2010
    Mechanical Fabrication Complete
    Well, all the mechanical fabrication is done and all three axises are moving as they should. The limit and home switches all seem to function correctly. I've got the Porter Cable 892 Router mounted using a bracket from K2. At this point all that's left is to rangle the cables so they don't get fouled. Then I can start cutting!
    Attached Thumbnails Attached Thumbnails Frankenbot CNC Router-crw_3213.jpg   Frankenbot CNC Router-crw_3216.jpg   Frankenbot CNC Router-crw_3217.jpg   Frankenbot CNC Router-crw_3222.jpg
  • #29
    Jul 2010
    Hold downs and collets
    Installed T-slot tracks and hold downs from Rockler and ordered a set of Ultra-Precision collets from Think & Tinker. Once I get all the cables and wires worked out I'll make a cover for the exposed terminal strip on the end of the table.
    Attached Thumbnails Attached Thumbnails Frankenbot CNC Router-crw_3223.jpg   Frankenbot CNC Router-crw_3225.jpg
  • #30
    Apr 2007
    Quote Originally Posted by dpgoldberg View Post
    Looks like you are ready to do some serious cutting. It would be a shame to mess up that nice tabletop by cutting through the project material. If you keep some low cost luan door skin sheets around you can cut it to size and put it under the material that you are cutting. Then you can cut slightly through into something other than your table and T-slots.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  • #31
    Jul 2010
    Quote Originally Posted by CarveOne View Post
    CarveOne
    Already doin' it! That previous picture was just to show the clamps in action. Here are some pictures of some of the first parts I've cut out, with a disposable layer on MDF underneath. There's also a photo of the vacuum hose attachment, which was in fact the first thing I cut with the machine. Once I get some brush material I'll make a full on Dust Shoe.
    Attached Thumbnails Attached Thumbnails Frankenbot CNC Router-crw_3230.jpg   Frankenbot CNC Router-crw_3232.jpg   Frankenbot CNC Router-crw_3233.jpg   Frankenbot CNC Router-crw_3226.jpg
  • #32
    Apr 2007
    I've been thinking of doing that on a 48" section of my table the first time I surface plane the top or replace the spoil board layer. There are shallow cut marks in the top now. The T-track comes in 48" sections, and it would be too expensive to do it over the full 134" cutting length. The simplest method I have been using for MDF and wood is to drill 1/16" holes at the corners of the material and use 1-1/4" brad nails to hold the material down. I trim the ends a little to get rid of the holes. Brad nails put little holes in the table top, but there is no real harm to the MDF table top, and they hold really well. A carpenter's chisel will pry the material up easily.
    CarveOne
    CarveOne
  • #33
    Jul 2010
    Another option would be to lay down a full sheet of 3/4" of 1" thick MDF and cut you own T-slots using a bit like this one from Rockler.
    Hanging Slot Router Bits - Rockler Woodworking Tools
    It takes very little clamping pressure to hold down a workpiece and the MDF slots are likely to hold up just fine.
    Another, in between option would be to buy some lengths of 1/2" x 3/4" rectangular aluminum tubing and use the machine to mill a 5/16 slot along the entire length. Then use the machine to drill and countersink mounting holes every 4 inches.
  • #34
    Apr 2007
    Your second idea with the rectangle tubing sounds pretty reasonable for a long table like mine. I'll keep that on my back burner for a later upgrade. When I don't use a bit that lifts the material I just box it in with wood strips using the brad nails and it works well enough. Sometimes the wood strips have a little ledge on them to help hold material down. I'll do that when I cut the aluminum router mounts for my new PC7518 router. That will be a good project for a video.
    CarveOne
    CarveOne
  • #35
    Jul 2010
    T Slots - Cheap and Cheerful!
    So I dug around in my box of router bits and it turns out I had one of those T-Slot cutting bits. So I cut a little test piece. First a 3/8" wide by 3/8" deep slot was cut with a regular straight bit, then the slot cut with the slotting bit. The resulting slots are amazingly strong, certainly strong enough for this application. I wish I'd thought of this before spending $125 on aluminum T-Slot extrusions. (Well, not really, the anodized blue looks really sharp!)
    I think I linked to the wrong bit before, the correct one is:
    Rockler T-Slot Cutter Router Bit - Rockler Woodworking Tools
    Attached Thumbnails Attached Thumbnails Frankenbot CNC Router-crw_3239.jpg   Frankenbot CNC Router-crw_3240.jpg   Frankenbot CNC Router-crw_3242.jpg
  • #36
    Jul 2010
    Rebuilt Z Axis
    I guess one of the great things about this hobby is learning what works and what doesn't and improving our machines. After only a week of cutting with my newly finished CNC, it was obvious that the salvaged linear mover I was using for the Z axis just wasn't up to the task. Too much lateral slop.
    So I tore it apart and rebuilt the moving carriage. I used bushings instead of bearings and mounted them based on idea perfected by John (Microcarve) on his brilliant little desktop machines.
    For each rail, a pair of bearings was press fit into the ends of an aluminum tube. The tube was 1.25" OD x .75" ID. The ID was about .010" undersize so I bored out each end of the tube on the lathe to just .001" under the OD of the bushings (.75"). Each tube was milled flat and drilled and tapped for mounting to the carriage plate.
    A new carriage plate was made from .375" aluminum plate. Holes were drilled and tapped for mounting the bracket for the anti-backlash nut and the K2 router mount. Holes for the mounting screws were drilled and counter sunk. The holes on for the bushing tube on the left were drilled just to fit the #10 cap screws so the plate would stay square to the rails. The holes for the tube on the right were drilled and countersunk oversize so the tube could be locked down once the rails were assembled, to avoid binding.
    I was able to reuse all of the rail and lead screw assembly with no modification. The end result is simple, solid and works like a charm! It took only a couple of hours to make the new parts, far less time than I've spent monkeying around with the old bearing slide trying to get it to work.
    Attached Thumbnails Attached Thumbnails Frankenbot CNC Router-crw_3244.jpg   Frankenbot CNC Router-crw_3245.jpg   Frankenbot CNC Router-crw_3246.jpg   Frankenbot CNC Router-crw_3253.jpg
  • Page 3 of 4 FirstFirst 1234 LastLast
    1. Need Help!- with a Precix Table Router with Perske router
      By SignShop Grunt in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-08-2010, 05:08 PM
    2. CNC ROUTER KIT instructables router project
      By spotlight3d in forum EBAY ADS
      Last Post: 12-30-2009, 05:11 PM
    3. Newbie- Does anyone own a EZ Router Machine? Plasma or Router.
      By sngatlanta in forum Commercial CNC Wood Routers
      Last Post: 04-11-2008, 11:48 AM
    4. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
      By Apples in forum DIY CNC Router Table Machines
      Last Post: 09-23-2006, 04:33 PM
    5. Surfcam PP for Isel router / Precix router
      By IvanTochev in forum Post Processor Files
      Last Post: 05-12-2004, 01:27 PM
